Question about Sony Handycam DCR-HC28 Mini DV Digital Camcorder
Sony hand cam DC R 28 The tape door is not closing
  • 172 Answers
Its because mechanical cable or flex is damage.it need replace cable or complete mechanical
Posted on Sep 02, 2010
Why doesn't commercial refrigerator close all the way
This sounds like the cams that control the close location are out of alignment. Loosen up the hinges, align door and duct tape it in place. Tighten hinges, remove tape and you should be good to go. Door is heavy so unload first and have an extra set of hands.
May 21, 2014 | Maytag MSD2732GR Side by Side Refrigerator
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
Aug 08, 2011 | Sony TC-WE675 Single Cassette Deck
Door doesn't close tightly. How to adjust cams to close door?
loosen up the hinges, align door and tape it in place. Tighten hinges, remove tape and your good to go.
Mar 31, 2010 | Northland 24" Built In All Refrigerator -...
Tape door will not stay closed. shut tape compartment door...runs for 3 seconds...reopens.
It is possible on the CAM mode the tape reached to the end, or this is
typecal problem from Sony the sensor it detecting 2 reels to turning the tape were faulty.It require to replace the cassette compartment or it call LS chassis assy. It will cost about $200, $250 in Australia to repair it
Jan 08, 2010 | Sony Handycam CCD-TR96 Camcorder
My sony handycam dcr-hc26 door won't close. error C:32:11
Remove battery/ power source from camcorder for minute, reattach battery/ power source and close the tape door.
If that does not solve problem then I'm afraid, tape mechanism got defective and will be replaced.
Let me know if you need tape mechanism part number info.
Thanks.
Dec 09, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
The tape carrage wont load the tapes but it will go into the load position without.
I have a sony cam myself. If the cam is empty, you open the outer door(swings out), and the load/unload mechanism rises up and pops open allowing tape insertion. When a cassette is placed into the mechanism, you press where it says "push" and then the drive pulls the tape down and into the unit. Then the outer door is closed and you're ready to tape. IF YOU PUSH DOWN ON THE TAPE WHILE IT'S BEING PULLED INTO THE UNIT IT WILL STRIP GEARS INSIDE. The gears are made of nylon to prevent serious damage to motors and other circuitry. This transport setup cannot be forced at all. If any type of mis-alignment occurs, the mechanism is supposed to stop and back up--allowing the problem to be corrected. If it is damaged, the cam must be repaired. There is critical timing involved in replacing the tape carriage.---Rick
Sep 10, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Tape door won't shut and message C:31:40
You need a qualifier Tech trained from Sony to repair your CAM
Your problem is that the cassette compartment it had 2 sensor and a few contact to detect what kind of tape you are insert like normal, metal or Digital 8 or Hi 8 or 8 Standar or cleaning tape so the system control would auto adjust according the tape
Those contact conducted by flexible cable now that FC may be cut or the sensor faulty when you insert the tape the CAM detected 1 side of the tape so it juded like some thing wrong with the tape then it will not load the tape in because it designed to protect the tape and protect mechanism
Without the tape no problem because the sensor or contact at the right corner of CAM did not detect any thing
If You want to know how it detect what kind of the tape, just turn the D8 tape up side down, you can see the holes on the left and right corner where is the tab for save and record
You need to replace 1 chassis LS assembly it cost about $250 to $350 if you are in AUSTRALIA
I hope that give you some ideas
Nov 25, 2008 | Sony DCR-TRV285E Digital-8 Digital...
My camcorder tape door won't close
Try removing the battery for a few seconds, and then re-inserting. This seems to reset something on my DCR-TRV20, and it starts closing properly.
Jun 15, 2008 | Sony Handycam DCR-HC48 Mini DV Digital...
Door Jam
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Nov 26, 2007 | Sony Handycam DCR-HC96 Mini DV Digital...
Sony Handycam DCR-HC28 Mini DV Digital Camcorder Logo
198 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
