Question about Canon PIXMA iP90 InkJet Printer
Not printing all info
When i try to print something it only prints out some of the text
  • 549 Answers
Do you have the paper size set correctly such as 8.5x11 inches in the printer setup page?
Posted on May 10, 2008
  • 3,037 Answers
Is the text getting cut off?
If you check the print preview is it all there?
You have the paper settings right?
Please let me know, you can download the drivers from the canon website.
If you need any help with any of the above, please let me know and I can give you more specific directions, also please respond to my questions, for a better understanding of your problem, thanks.
  • Benjamin Patri
    Benjamin Patri May 14, 2008
    Please don't forget to let me know your thoughts about my
    solution.
    If your problem is fixed, please rate this solution as that is one of the
    biggest aspects of how this website works and in order to receive any credit in helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to
    help.
    Thank you
    Genius:
  • 3,422 Answers
HI,
You can try reinstalling your drivers.This will fix your problem.
If you need anymore help let me know.
Goodluck,
Please don't forget to rate the solution
  • Canon Master
  • 13,433 Answers
Check your printer settings
Id recommend you uninstall and then reinstall the software and drivers to get everything back to normal.
    Genius:
  • 3,587 Answers
Try a test page first, please, and let us know the results.
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
How to print label on b-sx4 label printer
You must use the option send file to printer in the seagull driver not print else it is converted to graphics and sent to the printer.
May 16, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Zebra 105SL Prints fine through Zebra Setup Utility, but prints plain text when file copied to port. Win XP. The setup utility can never get Version Info from the printer, but Windows shows the printer...
possible fonts issue. try to change the font from the text, check setings from the driver.
try to print from the driver (test print)
Try to print from Word (need to ajust the page) with diferents text fonts.
you can check the correct firmware ( be ware with the information about the serial number) ATENTION!!! wrong firmware can cause PRINTER DEAD!!!
Install lates firmware to the printer.
Oct 12, 2009 | Zebra 105SL Thermal Label Printer
Print size has changed to very small off internet
Assuming that normal printing is fine, This is due to the size of the print in the email. To output larger print you'll have to copy the email into a document, change the size and then print the document.
Apr 30, 2009 | Dell 924 All-in-One InkJet Printer
IP5000 3ebk problems
I had a similar problem. Pages in blue, but nozzle check in black. Tried what you tried. Changed the ink ($). Still no change. Then tried the maintenance option to clean the bottom plate. And now it is working. Go figure.
Apr 08, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Printing
Check on your color (not mono) ink levels. If they are low, this could cause this.
Technical info: On this printer, envelope text is printed in "composite black" which means we mix the colored inks to make black. This is done for envelopes and not letters because of the ink properties which resist water and smear. If one of the colors is low, you'll get something other than black.
Mar 24, 2009 | Lexmark Z53 Color InkJet Printer
MP 780 DOESN'T PRINT
Try printing something in a colored font, like red or green and see what happens. This printer uses two black ink cartridges. It uses the larger one for black text printing. If it is dry, blocked, or damaged, your text (usually black) will not print. Changing to a color font will rule that out.
Good luck.
Feb 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
HP Officejet 5610 All-In-One print text but no image?
I found what might be the solution to this while searching for a problem for another printer series on HP's site. Go to the Printed Page Is Different Than What Appeared on Screen page and scroll down to "Missing graphics or text, or blank pages"
Sep 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Every other line prints only bottom half of text.
I have a psc 2355 printer which only prints half of text then the next lines are ok then it repeats only printing half text. I removed my ink cartridge and wiped the ink ports with a tissue heavily moisten with water. Repeated this several times and then gently dried with a tissue. The problem was fixed!!
May 08, 2008 | HP PSC 1610v All-in-One Printer
Error message; no printing of text
What application were you trying to print from at the time. Does the printer give this error message all the time or only from this program? I need this info to assist you bzoe...lilacgerry
Aug 30, 2007 | Xerox WorkCentre M940 InkJet Printer
Canon PIXMA iP90 InkJet Printer Logo
old marine
old marine
