Question about Fusion REAM45020 Two Channel Car Amplifier
Red light all the time. happened of a sudden and was working prior to this for a month fine. It doesnt go.
Power button blinks red seven times on a 2007 Panasonic flatscreen VIERA.
I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The "pop" is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
Jan 15, 2013 | Panasonic VIERA Televison & Video
Refrigerator quit working, power to compartment lights OK
If this is an American model refrigerator I will need to know the model number to see what may be happening. Can you post the model number? Thanks Sea Breeze1_10_2013_2_30_52_am.jpg
Jan 10, 2013 | Refrigerators
Red light laser doesnt come on anymore
Same thing happened to me today (after 1 day of working). I called the toll free customer service line 1-888-726-6369, told them what happened, they asked for the manufactured month (printed on sticker on back of unit, mine wash March 2012), and will be sending a replacement unit via fedex. Try it!
Oct 21, 2012 | FroliCat BOLT Laser Cat Toy
My Sharp 32 inc turn off suddenly, power green light turn to red, went turn on again screen ok for 5 to 10 second and start blink 3 time and screen turn off and power light change back to red. What...
sounds like something is shorting and the safety on the psu is kicking in.is the backlight behind your screen flickering prior to it cutting out. if so sunds like a cft has gone faulty. can be fixed though
Jun 08, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Vivitar 8010 camera wont turn on, but has power, red light is on.
I suspect you battery has died,this happened to me the other month.
Easily fixed by buying a new battery, got mine off Ebay £7.99
May 05, 2010 | Vivitar ViviCam 3915 Digital Camera
Xbox 360 turns on and works fine for about 2 minutes and then it suddenly turns off with 2 red lights appearing
your console is now dead it will happen all the time if it does not get it repaired even if it is under warranty microsoft doesnt fix it right either you can try to fix it yourself or you can send it in to our shop here in florida we have a 2-3 day turnaround we do over 100 of these a month for 1,2,3 red lights email me at price1150@bellsouth.net for questions
Nov 21, 2009 | Video Game Consoles & Games
Electrical problem on my 2000 dodge intrepid
Check under the hood at that fuse box there should be a 40 amp fuse in a slot marked "run ign" or some such thing, for about $3.75 if you replace that fuse it should start working again, this just happend to me a month ago.
Jul 09, 2009 | 1999 Dodge Intrepid
Intermittent P0136
Try some "Heet" or similar moisture remover for gas tank, just in case & see what happens. Good time of year for that.
Jun 05, 2009 | 2003 Toyota Camry
Fusion REAM45020 Two Channel Car Amplifier Logo
29 people viewed this question
Top Fusion Car Audio & Video Experts
Brandon Berry
Brandon Berry
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
