Question about Konica Minolta Office Equipment & Supplies
I have a konica 7030, there is no phone jack but it has a fax button, how do i connect to make it fax
  • supatech280 Sep 02, 2010
    t the back of the machine there are 2 serial; port c onnections and one that is very small and round with a single pin. From reading all the info it appears that this is a interface of some sort. Please shed some ligh
    President:
  • 1,514 Answers
In order to make this machine send faxes it needs to have the optional module FK 101 fitted.
Posted on Sep 02, 2010
  • Joe Bannon Sep 02, 2010
    I'm sorry I don't know what those connections are used for.
C352 fax not working
check the phone line is it digital if so no go has to be analog or old phone line, is the fax cable plug into line jack on copier not tele? have phone check line have you called you fax line any noise or crackling on the line, get the fax noise.
Mar 12, 2014 | Konica Minolta bizhub C351 All-In-One...
Cant find phone connection on my konica 7030
My Guess.
On the rear were printer cables power cable enter, there shoiuld be either a plug hole for the cable, it might have a plastic cover hiding it.
Jan 28, 2013 | Konica Minolta Office Equipment & Supplies
Cant find where to connect the phone line
what make and model copier? if there is no rj-14 jack(s) on the copier then it does not have the fax option installed. Many models have a fax button but do not come standard with the fax card. Usually an FK-502 or an FK-503 fax system.
Can't print to Konica 7030 via Parallel
You do not have the print/scan option installed on your copier. If you did you would have an ethernet port on the machine for network access and when you press the print/scan button on the control panel you would be able to access those functions. The fact that you can not means that the machine can not see that option because it is not installed. The parallel port is common and is used for uploading of firmware into the machine.
Thank You for using Fixya.
Apr 30, 2010 | Office Equipment & Supplies
F 35 7 on a Konica 7030
F35-7 is fuser error on a konica 7030. Resetting the fuser error might just fix your problem. First turn your copier on while holding down the 2 and 5 key. Next press 1 for soft switch setting, then press the left up arrow key to 3 and the right up arrow key to 1, now press the OFF key to change the data to 0 (it should read 3-1 :0)press return. Power the machine OFF/ON. If the problem persist then you most likely have a bad thermistor, however it can also be a bad heat lamp or thermistat.
May 11, 2009 | Office Equipment & Supplies
Konica minolta 7030 drum replacment
Is this a photocopier? If so then you will need a technician to fit this for you
Jan 02, 2009 | Office Equipment & Supplies
I can send faxes, but not receive them on Canon Pixma mx310
Do you have the phone you are answering with connected through the fax machine? If you have the machine set in 'tel priority' mode, the machine will not begin receiving a fax until you press 'FAX' and the 'color' or 'black' button. Alternatively, if you have your phone connected to the 'telephone' jack on the machine (next to the 'L' jack), you can press '2' and '5' on the telephone keypad to turn the machine on in fax receive mode.
Oct 15, 2008 | Canon PIXMA MX310 All-In-One Printer
Will not send faxes
Make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to add a telephone to the fax. If it is connected properly, try calling your fax from a cell phone and see if it answers. If the fax answers, hang up and press the HOOK button on your fax and use the fax keypad to call your cell. If the cell rings, answer the call and listen for the fax machine tones. If you hear the fax on the cell, you may have to change your machines TRANSMIT or DIALING settings.
Jul 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
