Question about Miele Novotronic Premier 500 Front Load Washer
My Miele washing machine rinse light keeps flashing and icant seem to use it at all it wont wash drain or anything else
  • 14 Answers
SOURCE: Miele Premier novo washing machine
Faulty cold inet valve most likely the problem or cold tap off Good luck
Posted on Sep 14, 2007
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
  • 417 Answers
SOURCE: washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Posted on Jan 23, 2010
Testimonial: "that worked a treat thanks"
  • 70 Answers
SOURCE: miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Posted on Apr 01, 2010
Testimonial: "thanks, you confirmed what we sort of expected"
Why does Miele indicator stick on 'rinses'?
Hi dear. Your machine may have one of the three factors playing up.
1- Tacho generator or it's plug on motor
2- Motor carbon brushes
3- Power/ electronic module faulty. Thanks.
Mar 24, 2016 | Miele Washing Machines
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Rinse light flashes on miele w828
1) the water must be preheated, test the heating element if is defective
2)drain line is clogged proceed to fix it see the diagram
3)some sock must be removed, use plier
4)pump defective, inside with the propeler, replace
5)frozen pulley pump, replace
6)improve the drain, if about 4 inches cut of the diference.
b) if lower , install air/gap siphon break assembly.
God bless you
Jun 25, 2012 | Miele Novotronic Premier 500 Front Load...
Miele rinse light keeps flashing
did you check the DRAIN PUMP MOTOR ? IT COULD BE CLOGGED or something blocking the impellers
Apr 19, 2008 | Washing Machines
Miele Novotronic Premier 500 Front Load Washer Logo
210 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
