When i start my conputer invalid boot.ini to C:/ducument apear before open.
    Champion:
  • 331 Answers
When you start your computer it says invalid boot.ini and then freezes there? Or, your system is booting into windows; and your receiving another error ?
Posted on Sep 02, 2010
Invalid boot.ini when starting PC
The boot file is misplaced in your PC. to solve the problem boot it from an OS installation disk. then when you get the phase of installing there will be an option called "repair your computer". click on it and follow the instructions..(takes under 5 minutes) also use startup check to remove common errors..i can give you an accurate description if you post the correct OS i can give more accurate steps.
Apr 05, 2014 | Microsoft XP Computers & Internet
Invalid boot file ini fix dell opti plex 270
bonvicin66,
Unfortunately, you are going to need to have a Windows Disk to run a Repair Install from the disk. If running a repair install does not resolve the boot.ini error you will need to format and reinstall Windows.
To get a Windows disk you can search the internet for a disk. If you are in the US you can try getting a disk from the link below.
Dell Backup Media Online Request Form
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 15, 2013 | Dell OptiPlex GX270 PC Desktop
I have 2 HDD's in my PC - both with Win XP Prop
Boot.ini is correct, but looks default is booting from Disk2 and partition 1 which is your G:\ 500 GB.
Try Copying boot.ini from c:\boot.ini to g:\boot.ini It might help
In your example I see missing "\" after partition(1), may be typing mistake, but in real time can generate error.
You boot.ini looks exactly same in both drive c:\ & G:\
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(2)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="GUY DRIVE XP Professional" /noexecute=optin /fastdetect
Note: boot.ini will be hidden and readonly file. You need to unhide the file and remote the read only option and then only you will be able to save the boot.ini file
Hope this helps
May 22, 2010 | Microsoft Windows XP Professional SP2
It keeps saying invalid boot,ini file booting from c:windows
get a boot manger as it is safe to edit in GUi mode than in text mode;and fix it
Nov 24, 2009 | ASUS Eee PC 900 Notebook
BOOT.INI deleted. How to re-create this file?
type in run "cmd" then presss enter then type "bootcfg /?" it gives u some help .
Dec 28, 2008 | Microsoft Windows XP Professional for PC
Hello, I have 2 Operating Systems in a computer namely Windows XP(SP3) in C:\ & Windows Server 2003 in D:\ . I've deleted the file BOOT.INI accidentaly form X:\ drive(X:\ means all drives like...
That's not a virus. Boot.ini is a default file needed for Windows OS to boot.
Fortunately, you can recreate the boot.ini files
This is a sample of the above Boot.ini file with a previous installation of Windows 2000 on a separate partition. [boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows 2000 Professional" /fastdetect
Simple way to add operating system on a separate partition:
At the command prompt, type: bootcfg /copy /d Operating System Description /ID# Where Operating System Description is a text description (e.g. Windows XP Home Edition), and where # specifies the boot entry ID in the operating systems section of the BOOT.INI file from which the copy has to be made.
timeout=30
[operating systems]
Please rate this if you found this answer helpful. :)
Laptop
You may want to try to reset the BIOS to DEFAULT setings.
If this does not work...Try this turn the pc on and then press F8 a few times to access controlled boot precedure. You will be given some options and you should select "Start Windows in Safe Mode" . Hopefully, you can boot and inspect you boot.ini file.
Hope this helps
Justin
May 06, 2008 | Compaq Evo N610C Notebook
Invalid boot.ini
One of these two methods should fix your problem......... -------------------------- go to run and type in MSCONFIG. Then click on the "Boot.ini" tab. First, make sure if using XP Pro that the following is listed: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect - this is the boot.ini information from XP, straight from the Microsoft Web Site. All the information below [operating systems] should be on one line! If you have a blank boot.ini file, copy and paste this information - if all information is already there, then don't change anything. Next, click the button that says "check all boot paths". You should get back a message stating that everything is good (the computer checks to make sure the boot.ini file is compatible with Microsoft Operating Systems). Next, assuming your computer likes the boot.ini file that is in there (and it should), then click the button that says "set as default". By doing this, you have now created a new (modified) boot.ini file that is a carbon copy of the original. Click apply. You will be prompted to restart. Before doing so, go back to MSCONFIG and in the general tab you will see that "use modified boot.ini" should now be checked. During reboot, you should not get the invalid boot.ini message (at least I didn't). What you will get is a message (after reachign the desktop) stating that you are not using the defaults or something like that and do you wish to go back into MSCONFIG to restore the default settings. Since your new boot.ini file is exactly the same as your original, click no and check the box to hide that irritating message. ------------------------ Or you can try this method.... right click on my computer go to properties then click the advanced tab then cilck settings under start up and recovery under system startup then click edit and paste [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect --------------------------------- Peter
Oct 04, 2007 | Intel Motherboard
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
