Question about Dishwashers
Winterhalter gs 302 error code 4 - Dishwashers
2 Suggested Answers
SOURCE: winterhalter gs502 dishwasher-error code 15?What's
The float switch/level sensor in the rinse boiler has not activated. This could be a faulty solenoid not letting the water in(assuming the isolating valve is turned on), or a faulty float switch/level sensor. This would result in water overflowing through the rinse arms and the overflow in the rear of the wash tank.
Posted on Mar 29, 2011
How do i stop water coming from under the door on my winterhalter gs 202
sounds like the rubber gasket is damaged, sorry Done these before and a headache to replace on most models
Dec 20, 2014 | Washing Machines
Winterhalter error codes 23
Call customer support
Jul 07, 2014 | Dishwashers
Winterhalter gs502 and getting error 11
Klix-on on motor has failed. (This is often due to overheat) Clear dust and dirt from around motor to restore cooling may be the answer. .
www.cearcommercial.co.uk/.../winterhalter/winterhalter-wps-reminder-er...
May 21, 2014 | Dishwashers
Winterhalter gs 302 error Code 15
haw can i chainge a float switch on a winterhalter gs302 ?
please any one can hellp
Mar 17, 2013 | Dishwashers
How to clear error code SC302, Dsm615 nashuatec
Yes, mine were successfully RESET from the error code SC:552 and SC:302. Machines runs good, but i about to wander what could be faulty inside, it took one month after error code 302 exist. Mine was exactly DSM615 same model same error code 302 (this is really 302) which resolved by reset. Hopefully machine will run good for two months.
To RESET it
1. Press Yellow button
2. Press 1, 0, 7
3. Hold Orange button for 3 seconds
4. Select MODE 5
5. Select Clear Memory (or something like it) (801)
6. Select 002-Engine
7. Select EXECUTE
8. Turn the switch off and leave it for a minute
9. Turn back machine On.
10. Done, or else there could possibly something else.
Good Luck....
Thanks for using Fixya.
Mar 04, 2013 | Office Equipment & Supplies
Error code 23 on winterhalter gs 502
hi i a have a problem with dish washer it shows error 23 .and the ,model is GS 502,GS 515 .So how can i rectify the problem .thanks in advance.
Dec 28, 2012 | Dishwashers
Winterhalter gs502 dishwasher-error code 15?What's mean fault code 15?
Mar 18, 2011 | Dishwashers
Could you please tell me what error codes 21 and 6 relate to on a Winterhalter GS502 dishwasher. Many thanks. Barry CER
error 6 relates to a blocked drain pump. if the drain pump is working ok check if the tank level sensor is operating or if the air chamber in the wash tank is blocked.
error 21 relates to the drain pump being activated. normally related to error 6.
also check water inlet solenoid valve is working correctly. ie not blocked or passing.
all parts of the machine can be activated manually by entering service mode.
when machine is off press service button or switch on main pcb.
p00 appears. press and hold main wash button. --- appears. using the long and short wash buttons you can scroll through parts of the machine. displayed as a01 a02 a03 etc.drain pump is a12 solenoid valve is a13. these are activated by pressing the button. when activating the drain pump the display will count down. this number is the water level in the wash tank. if it's counting down the level sensor is ok.
hope this helps
jarv
Mar 29, 2010 | Dishwashers
Dishwashers Logo
2,078 people viewed this question
Top Dishwashers Experts
Owen Barnes
