Question about Minolta magicolor 2300W Laser Printer
Identifies itself as NaltecN1, which is a controller chip inside the Minolta Magicolor 2300W
The Magicolor 2300W was already installed, but it has been rarely used. It has barely done 1500 copies in its life. This problem originally occured intermittently, and fixed itself after rebooting th eprinter, but not today, after several reboots.
When the printer is turned on it claims to be a NaltecN1 and wants to be reinstalled. The correct driver for this printer will not satisfy this misidentified printer and the Status Monitor misidentifies the printer, and refuses to work with it, so that I can't use the Status Monitor to at least remove the toner cartridges to give them a shake, because, although the Color Toner low light is on, and it won't print, I know that there is at least 95% toner in there, from the previous time that the Status Monitor actually worked. (This has been a very annoying printer throughout its life, being entirely dependent on Windows and the Status Monitor, so that I can't print to it from any of my Macs, only from the Windows machines.)
I have tried this with parallel and with USB on a desktop and a laptop running Windows XP SP2.
  • 4 more comments
  • jesfish May 17, 2008
    I'm having the exact same problem
  • Anonymous May 26, 2008
    I have the same problem. I think MS Windows has installed a **** update and now there is the problem
    I have the same problem. My printer doesn't works on three PCs.
    One day before, it works well, but today it is a NALTECN1 and want's to install a driver.
    A week beform, i have the same error, but i made a restore of windows an it works again. I think, there is a defect on the printer.
  • Anonymous Jan 08, 2009
    I have the exact same problem as the one posted by iangr on May 10, 2008.
  • Anonymous Jan 16, 2009
  • Anonymous Feb 15, 2009
    Make the firmware-update, and the printer works again. Use a parallel-port-cable and don't forget to change LPT1 to FILE before updating the firmware and change back after done.Then switch the Minolta off and on, and it works agian.
    New Friend:
This is a known problem of the Flash EEPROM on the controller board losing data. The EEPROM is an Atmel DataFlash AT45DB021B type.
If you can still get the printer to boot (like you indicated that it was occasionnally possible at one time), do a firmware upgrade immediately. This will erase the EEPROM and write it again, thereby writing fresh charge into the storage cells and allowing them to hold the data for some time again.
If the printer won't ever boot properly, you'll have to remove the EEPROM (desolder it from the controller board), get a replacement, program the replacement with an EEPROM programmer, and put (solder) the replacement back in. You can also rewrite the original EEPROM with an EEPROM programmer, then it will work for a while again, though it's not known for how long exactly (sooner or later one of its storage cells will deplete again).
For programming the EEPROM (new replacement or original part rewrite) you will also need the firmware binary file.
Konica Minolta does not provide one in the correct internal EEPROM format, but you can download an archive called "MR1_3.zip" from their website, and this will contain a firmware file "mr-3926.nal" with a size of 128 kB. It will be missing some padding data so you can't write it directly into the EEPROM, but it can be converted. The conversion can (in theory) be done in a hex editor, but it would be a long and tiring process, so better write a small program to do it. Here is the algorithm:
1. Read from the source file one full 256-Byte block at a time.
2. If this is a complete block then skip steps 3, 4.
3. If this is the last block (it is smaller, not full 256-Byte size)
4. => then fill it up with 0xFF bytes to full 256-Byte size
5. Copy the (now full) block into the destination file
6. Write additional 8 Bytes after each block to the destination,
7. => the data to write is hex: "FE, A6, 7E, 0D, AD, 73, F8, 26"
8. Goto step 1, process the next block from the source file.
When all is finished, the resulting (destination) file will be 132 kB (135168 Bytes) in size total. This file can now be written directly into the EEPROM with an EEPROM programmer. When you put the newly written EEPROM back in, the 2300W should work. At least mine did.
Posted on Feb 07, 2016
  • Dimitrij Klingbeil
    Dimitrij Klingbeil Feb 07, 2016
    Obviously this was meant for people with the same problem doing a google search (the site comes up on top). The original poster will of course have junked his printer a long time ago by now.
I finally was able to talk to a Minolta repair person and here is what they said: The Naltec message is an indication that the
controller printer's controller board has failed. I asked for a price quote on the part and was told it is either $160 or $560 for the part. Since I needed toner cartridges, it was much cheaper to buy a new printer.
Posted on May 28, 2008
A firmwareupdate is not possible, because the correct driver is not able to be installed, and so you can't connect the printer.
I have the Problem the color toner led is always on. I have every toner cartridge opened an reset the switch for toner emty, but it doesn't work
Posted on May 27, 2008
    Champion:
  • 214 Answers
Pleas try to update firmware. should help
find the latest FW from konicaminolte.eu
Minolta 2300w slight creases
Are using the authorized media (paper) might be to thick check you paper weight and what the manual says.
Dec 29, 2013 | Minolta magicolor 2300W Laser Printer
Konica Minolta Magicolor 2300W firmware needed
firmware is located on secure web site try having a Konica Minolta tech come out and flash the firmware
Apr 15, 2010 | Minolta magicolor 2300W Laser Printer
Driver needed
cool never heard of the name but got the drivers
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=992&filetypeid=0&osid=17
all i can say is google is usefull
ALL HAIL GOOGLE LOL
need any more help just ask
Sep 26, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Not printing yellow (64% full)
Go to maintenance and purge ur cartridge.Cheeck regularly ur wiper maybe it will cause clog to ur cartridge.
May 20, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Driver
Here is the link to download your driver.
Thanks
Mar 12, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
I lost the cd for the install of magicolor2300W minolta printer
You can get your drivers and other information on this printer here - LINK
Dec 09, 2008 | Office Equipment & Supplies
Minolta 2300w windows vista
try changing a usb cable vista should find some new hardware
Jun 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta magicolor 2300W Laser Printer Logo
784 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
