Question about Dell Dimension 2400 PC Desktop
Dell 2400 does not recognize replacement hard disc drives or usb external drives.
  • ricky845 Sep 03, 2010
    Did all the things you suggested and got the results that concludes that the mother board is defective. Not wanting that to be the case I tried to reinstall windows and got an error message telling me to install software for the hard drive. Tried using an external drive, same results. Am I just whistling in the wind ?
  • 1,472 Answers
Ricky845
Looking at your motherboard info you only have an IDE controller it is possible that there is a problem with the IDE contoller.
However this is a old computer and it will not support over a 120gb hard drive on the IDE controller. So if you have a hard drive that is bigger than 120gb then you will need to purchase a controller card that will support the bigger drive.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Sep 03, 2010
  • Dell Master
  • 11,800 Answers
You need to determine if this is a hardware or software problem. First find out if the units get power take out the cover of the desktop and check one of the big 4-wire connectors if it's powered with a voltmeter: black (-), red (+5 volts) and yellow (+12 volts).
If they are ok then boot into the BIOS and in there find out if the internal hard disk is detected ; if it isn't then check that the jumpers and the cables are attached accordingly : the hard disk on its own cable, at the top connector and the jumper set at master. If this is the case then the motherboard of your Dell has died - time for a new pc.
If the disk is correctly detected in the BIOS then the Windows install disk is defective and you need another one.
Posted on Sep 02, 2010
  • Azrael SRL Sep 03, 2010
    Yes, the southbridge - the chip on the motherboard that controls the external connections like IDE and USB - has died and it can't be replaced since it's soldered there.
    Time for a new motherboard. But since your pc is a very old one and finding a new motherboard for it will be impossible (they're no longer made), time for a new pc.
Tying to add a hard drive to my computer using a USB adapter
you may have a bad hard drive or usb cable ,try a different cable or a different computer
Go to start menu ,right click on computer>manage>disc management
check if your drive pops up there ,if it does ,then you will need to format it
Feb 03, 2018 | Dell Computers & Internet
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
My WD2500XMS passport drice is powering up when connected by the USB cable, but it is not being recognized as an external drive and I am unable to access it
Some of the External drives comes with installation disc. before it can be recognize you have to download the driver at :
http://support.wdc.com/product/download.asp?modelno=WD2500XMS&x=5&y=14
The website only if you don't have the installation disc that came with the product.
Hope this solution works for you.
May 17, 2011 | Western Digital 250GB MyBook External USB...
My d610 does not recognize my cd drive
Is the USB-compatible drive recognized when connected to some other computer? If OK, then the drive is OK.
Is _ANY_ USB device (memory-stick, camera, mouse, keyboard, printer) recognized when connected to any of the USB ports on your computer?
If not, then the USB device-drivers for Windows have not been loaded.
Drastic: backup all your data files, bookmarks, and music, to an external hard-drive, and reinstall Windows from the Dell-provided "System Restore" set of CD-ROMs.
Nov 14, 2009 | Dell Latitude D610 Notebook
HOw to copy an external hard drive to an internal hard drive.
Open the folder you want to dump the files into, open up the external hard drive (plug into usb, and access from "my computer") ctrl + A to select all, and drag and drop
Oct 15, 2009 | Dell Dimension 2400 PC Desktop
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
How do i install a sandisk to my dell pc?
i had a dell 2400 to and there is NO memory card reader in it...you have to get a card reader or a usb adapter for it
Jun 08, 2009 | SanDisk 4GB microSDHC Memory Card
Dell 2400 wont recognize harddrive
I don't know how old the Dell is but I have not seen a BIOS setup routine that did not automatically find and recognize a new hard drive for many years. Perhaps the BIOS is the source of the problem.  Did you try the removed drive in another system? Did you check the CMOS backup battery? If this needs to be replaced, it may not recognize much of anything.
Dec 22, 2008 | Dell Dimension 2400 PC Desktop
Computer doesn't recognize the external drive
I asume the connection is via an USB?
Try another usb-port and see if that helps, if not try to connect the disc on another PC (maybe a friends pc) and see is that pc recognize the disc.
Nov 21, 2008 | SimpleTech Signature Mini 250GB External...
Dell Dimension 2400 PC Desktop Logo
32 people viewed this question
Alun Cox
