Question about Sony Cyber-shot DSC-H9 Digital Camera
Pictures come out very yellow/orange
I shoot interior homes for Realtors with a wide angle. I try not to use the flash because of the bottom shadow. My photos lately are coming out very muddy & orange. Any suggestions on settings. I'm going to try shooting on the quick action/sports mode today to see if that helps. I usually shoot on the landscape. Maybe that's my problem.
  • kontiepa May 23, 2008
    If using the lens hood, remove it, to avoid unwanted bottom shadows....
  • Anonymous Jul 27, 2008
    Same problem.took camera to where I bought it.they tell me i need to adjust the white balance setting but that is not working.
Remove the lens hood to avoid unwanted bottom shadows.
Posted on May 23, 2008
Nikon d-90, shadows in pictures
if you're using pop up flash, you'll get more shadows doing a portrait shot than a landscape shot just due to the position of the flash bulb and the angle the shadows are cast.
Jul 06, 2014 | Canon Rebel XT / EOS 350D Digital Camera
I purchased a Tokina SD 11-16 F2.8(IF)DX from Japan. When I returned home and tried it on my Nikon 50 it gave me great results when I use without flash. The problem is that when I use it with my integrated...
The angle od the flash is probably not large enought or wide angle enought to cover the area the lens takes in. try using a softbox or diffuser attachment and makes exposure adjustments accordingly
Feb 19, 2011 | Cameras
Fujifilm s1730 when i take a picture the buildings on the outside of the picture curve inwards and are not vertical as it should be
When shooting wide angle pictures (as you would be doing when shooting buildings) the sides of the pictures will curve inwards...the wider the angle, the more pronounced the curve will be. This is perfectly normal.
Oct 01, 2010 | Cameras
When taking indoor photos, sometimes i get shadows on different placesof the photo
If you're getting shadows on the bottom center of indoor photos when take with a flash, it is most probably due to the length of the lens on the camera.
A long, telephoto / zoom lenses will create the largest amount of shadow, while shorter and wide angle lenses will be least likely cast shadows. You can reduce the amount of shadow in pictures by removing the lens hood that may be on the end of the lens. The lens hood is to primarily to shield the lens from direct (sun) light, and probably isn't needed for indoor flash photography. Also, rely less on the zoom function of the lens on the camera and physically moving closer to your subject instead. The flash will need to provide much less light output and result in more flashes per battery.
You could use a separate flash - held off the camera so that the lens is not obstructing the light of the on camera flash. Using a Nikon Speed Light, you can set the on camera flash to provide a low output, that would be used primarily to trigger a Nikon Speed Light held by someone or arranged on another surface etc. Youtube is a great source for real life, practical "How To" videos for many operations of the camera and accessories.
I hope this was helpful!
Oct 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
We just bought d90 nikon camera and we found a small half-round shadow at the bottom of the pictures taken when we dont use the zoom lens, how do we correct this?
Are these pictures taken using the built-in flash and with the hood on the lens? If so, you're seeing the shadow of the lens hood.
Remove the lens hood when using the built-in flash.
Sep 17, 2009 | Nikon D90 Digital Camera with 18-105mm...
Problem- head shadow on flash shots taken in auto
Is it possible that you shoot with the lens hood on?
If so, at wide angles you get a bottom shadow of the hood.
Jan 07, 2008 | Nikon D40x Digital Camera
Is the wide converter attachable?
Wide converter can be attached by using the dedicated adaptor ring ZCA-300 and will provide equivalent to 26mm angle of view in 35mm film. The closest subject distance: Normal Recording mode: 70.5 cm (from CCD), 60 cm (from the front of wide converter) Macro mode : 20.5 cm (from CCD), 10 cm (from the front of wide converter) *1 Set the Lens acc. to Wide Converter. in the setup menu. (Optical zoom will be fixed at wide-angle end.) *2 Built-in flash can be used when attaching a filter, but shadowing may occur at the bottom of the image. In this case, use of program flash 5600HS(D), 3600HS(D), 2500(D) (sold separately) is recommended. *3 Filter with 52mm in diameter can be attached to the adapter ring.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Sony Cyber-shot  DSC-H9 Digital Camera Logo
131 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
