Question about Panasonic CT-20D11 20" TV
Panasonic tv old model
No picture , hissing sound from speaker
Panasonic 12 year old TV is making a clicking sound, when I turn it on, manually. The remote control cannot turn on or off TV, nor can I get any channels at all. What could be the problem?
Posted on May 04, 2011
Curve picture and auto shutdown
Posted on Sep 23, 2008
2 Suggested Answers
  • 9 Answers
SOURCE: Hissing sound from a Panasonic old TV...Sound and picture are OK.
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Posted on Feb 21, 2009
My Tv Is A Panasonic 51cm ctv model CS-21Z88SQ NO SOUND BUT ONLY PICTURES
Look on rear to see if a slide switch for internal/external speakers.
Look in menu to see if has a feature speakers on/off.
Put your ear straight to the speaker to see if hear anything; if nothing heard either bad speaker or audio circuit problem.
May 25, 2012 | Televison & Video
Sony STRDH510 has a hiss coming from the speakers when listening to FM stations, however, there is no hissing sound when watching tv and listening to the sound through the same speakers. Is there an...
This has nothing to do with the speakers.
Page 38 of the manual describes tuner operation. FM hiss usually indicates a weak FM signal or it's not tuned precisely. If the "ST" indicator is blinking and you select Mono does it get any better?
A 75-ohm FM antenna oriented horizontally will help bring in a stronger signal (page 29 and 73).
Dec 08, 2010 | Sony Audio Players & Recorders
Hissing sound from speakers and the picture turns off.
That model set was known for Chinese capacitors that failed, replace the power supply or look for bulged caps and replace them if your able to
Jan 06, 2018 | Philips 32MF231D Television
SOUND KEEP COMING IN AND OUT,LOUD HISS FROM SPEAKERS
theres a short in the wires either inside the box where the speakers are or the channels are blown.
Jun 07, 2009 | Panasonic SC-AK78 CD Shelf System
Hissing sound coming from speakers
I found out that if I manually turn the speakers down on the tv and then turn it up with the remote control the hissing sound goes away
Mar 18, 2009 | Toshiba 65HDX82 65" Rear Projection...
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Sanyo 24inch TV
Sounds like you have a bad speaker,or at the most the audio amp needs changing. Get old speaker out of another tv or stereo.
Oct 04, 2007 | Televison & Video
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Crackle noise and hissing - panasonic
solder all around the flyback area if this not resolve the problem replace the flyback
Nov 26, 2006 | Panasonic CT-32D12D 32" TV
Sanyo TV DS32224
Is the hissing or static sound comming from the speakers or from the back of the set itself?? Need more info please.
Mar 23, 2006 | Sanyo DS27910 27" TV
Panasonic CT-20D11 20" TV Logo
2,425 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
