Question about Samsung RS2578BB Side by Side Refrigerator
Need to remove the door bar - Samsung RS2578BB Side by Side Refrigerator
    President:
  • 1,891 Answers
Use a cc card and silde it under the edge and it will relace . mm
Posted on Sep 02, 2010
How do I remove flapper bar left French door Samsung RF266 fridge to replace gasket? Thank you
here is the manual on removing the doors. This will show you how to remove the door, then replace. http://downloadcenter.samsung.com/content/UM/200909/20090913021004593/DA68-01812H_RF266_RF263.pdf
Sep 20, 2016 | Samsung Refrigerators
Can I replace the door handle on my dishwasher?
  • i think you can but the only way to be 100% sure is by separating the inner part of the door from the outer. to do this remove the screwsalong the sides and rop of inner panel of the door leave the two screws securing the latch in place. as you remove the screws you will need to support the outer portion of the door, i do this by standing in front of the machine and with the door partially open and againdt my knees while reaching in and removing the screws this help to keep the two halves of the door sandwiched together untill all screws are removed at witch point th e door can be closed and the outer part of the door carefully separated enough to check for any wiring that may be attached to the door and or control panel. I recommend having someone to help you with holding the door together.
Aug 09, 2015 | Bosch Dishwashers
I removed the entire oven door to clean the oven. I am now having trouble putting the door back. Any suggestions.
The process is likely model specific. Your owner's manual might describe how to do it.
I have a Frigidaire/Electrolux (PLEB30S8CCB) and I find removal and replacement some what tricky. The owner's manual says to reverse the removal process, but I believe that that is incomplete.
To take it off, you open the door all of the way, flip up a metal connecting loop on each of the door sides to "bind" an upper J-shaped and lower L-shaped bar on each hinge, and pull the door out, while lifting up the outer handle side. (The pull motion frees the lower L-bar and the upward motion allows the J-bar to slip under a metal roller.)
To put it back on, each side of the oven has a two-part slot. The upper part is for the J-bar and the lower for the L-bar. Put the J-bars part way into their upper slots with the handle side of the door raised slightly to help slip under the metal rollers. Then ensure that the L-bars are fitting into their lower slots. Push the door straight in until a notch on the bottom of the L-bars sets on the bottom of their slots. The trick then is to push the door down to its fully open position, which allows you to flip the metal loops to separate the bars and allow the door to close. Note that pushing the door down makes some noise, but the door should go no more that level with the floor or something may be out of position.
Jul 31, 2013 | Kitchen Ranges
2001 hundai accent cannot unlock car doors with key. It worked on doors lastmonth. Have used lock deicer, wd-40 to no avail. Key works in ignition & trunk.
dose the key turn in the lock you could have a worn door lock where the plastic link bar on the back of the barrel gets a bit worn and just dosnt pull the link bar up enough , you realy need to remove the door pannel and really look at whats happening to the lock from inside the door checking the movement when you turn the key to unlock position you may even take up any play on the link bar to the latch lock by putting a slight bend in the bar to take up the slack
Apr 09, 2013 | 2007 Hyundai Accent GLS
Our back door (double glazed with locks at top, middle and bottom) has become permanently locked from the inside. It would appear that the lock at the top has bolted shut. (We have safestyle doors and...
Hi, W/D here.
Easy fix. Your upper locking bar has slipped. While someone is holding the door handle in the open position, you'll need to push the upper lock bolt back far enough to get the door open. You can slide it back carefully with a screwdriver or knife, a little at a time, while holding slight tension on the door with the handle. OK, door's open. Remove the inner door lock cover plate. The lever and locking knob will come off with it. Remove the mortise cover plate, on the edge of the door. Insert a small, thin bladed into the upper alignment slot in the lock behind the mortise cover plate, and loosen the upper allen screw behind the inside lock cover plate. Use the screwdriver to engage a slot in the locking bar, and raise or lower the bar until you have it level with the alignment slot. Tighten the allen screw.
Sometimes, the bar is so far out of alignment that you will have to gain access to the other end of the bar, in order to raise or lower it. This is done by removing the plastic cover on top of the door, and using needle nosed pliers to move the bar.
This should fix you up.
Best regards, --W/D--
Jan 28, 2011 | Locks & Locksmithing
I purchased a replacement side view mirror for a 2010 Silverado. I need to remove the door panel to get to the wiring connection How do I remove the door panel?
Try with this procedure...
1) Start with opening the driver's side door and lowering the window. Remove lock lever (1A).
2) Using a plastic pry bar [slotted screwdriver], slowly pry plastic cover to reveal screw.
CAUTION: These plastic covers are fragile and break easily. Be very gentle in disengaging them.
3) Remove screw with a 10mm socket.
4) Slowly pry plastic cover using a plastic pry bar [slotted screwdriver].
5) Remove the (2) revealed screws with a 10mm socket.
6) Pry off the door panel controller using a plastic pry bar. Disconnect wiring and remove the controller.
7) With the plastic pry bar, pry around the triangular panel as shown.
8) Lift up and slowly pull door panel out partially.
9) Release the door lever rod with a needle nose pliers. Remove and set door panel aside.
Keep us updated.
Jan 11, 2011 | 2009 Chevrolet Silverado 1500
Change drier belt on model number 41794702300 Kenmore stackable
1. UNPLUG UNIT. 2. On the front of the unit, remove two screws from the bottom panel. Remove it and you will see two screws holding the top panel and door in place. 3. Remove the screws and gently pull up and out on the door panel, INSURE NOT TO PULL ON THE WIRES LEADING TO THE DOOR SWITCH. 4. Remove wires from door switch. MAKE SURE TO NOTE WHICH WIRES CONNECT TO WHICH TAB. 5. Set door aside and you will have complete access to drum. Remove old belt, if necessary, noting now it is around the drum and weaved through or around the tension bar below the drum. 6. Once removed, or if there is no belt, or a broken belt, put the new belt around the drum so that the slack hangs below the drum. NOTE: You will probably see a black mark around the drum where the belt has laid, about in the middle of the drum. Lay the belt on that path. 6A. Lay on your back with both hands available, raise drum slightly to get access to the belt. Take slack in belt, raise tension bar slightly out of the way, bring belt UNDER the pulley on tension bar and put it around the pulley/spindle on the motor. (This may take another hand) Slowly lower tension bar back down to make contact with belt, applying tension to belt. 7. Get the door panel and reconnect the door switch. 8. Start to put door panel in place, while slightly raising drum to fit into position, careful to the raise to high or **** drum out of position off the back rollers or cause belt to slip off. Push door panel into place and put screws in. 9. Once you've got the door secure, test the belt by reaching inside and manually turning the drum clockwise until it seems to turn easily with not bumps. This is allowing the belt to settle into place and insuring it is not going to pop off; if it does, repeat the operation. If it turns easily, move on to... 10. Replace lower panel. 11. Plug in unit and test to insure drum moves freely. If not, you may need to readjust the way the door panel fits in place with the drum, or the belt on the tension bar. 12. If you need further help, please let me know.
Good luck. It's simpler than it sounds. G
Aug 02, 2010 | Kenmore 77062 Gas Dryer
Front right passanger window motor need to be repace, I have taken off the panel but unsure on how to get the motor out
First disconnect your negative battery cable. Next locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Once you have removed the interior door handles, unplug the wire clips to the switches. Next you will need a small pry bar to remove the door panel itself. The door panel is held in place by snap in clips; try to get the pry bar as close to, or directly under the clips, to prevent them from tearing out of the door panel. Once you have removed the clips, pull the panel upward to remove it from the door. You will need to remove the plastic sheeting to gain access to the window regulator. You will need to remove the regulator and motor as a single unit, and once it's removed you can replace the motor.
Install everything in reverse.
May 23, 2009 | 2004 Chrysler Sebring
N Reg Ford Escort Cabriolet, locking mechanism
By 'Black bar' do you mean the window guide? If so, this is usually held in place at the bottom by a bolt or screw &, once removed, the guide should pull out downwards. The window should be closed. Your latch might have a black, anti-theft cover on the inside of the door which will also need to be removed.
Jun 27, 2008 | 1996 Ford Escort 4 Door
Samsung RS2578BB Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
