I'm working on a 2003 dodge grn caraban and have a code p0206 inj.circ.open cyl.6,i check the conector with a test light eng.ruaning and have + on both sides and it supossed to have - in one side,ithing its the ESU problem? if i replase the ESU do i need to reprogmam or what could it happen if i don't.thenk you.dario
  • dario_garage Sep 02, 2010
    Thenk you to letme know.
    Brigadier General:
  • 7,191 Answers
You have posted the problem under PC Desktop category.
Kindly submit the question under the Dodge Caravan section on the website by clicking this link so that the top automobile experts can view and provide a solution to the problem.
Thanks for using FixYa.
Posted on Sep 02, 2010
  • AliTech110
    AliTech110 Sep 02, 2010
    Many thanks for the feedback and wish you all the best.
    Thanks again.
04 grd.chetrokee spec. edition 4.0L code P0206, open injector circuit.. Do I replace the injector, or is there a fix.. Thanks Ray
Do you know how to do a continuity test of the injector ? How to Check Fuel Injector Resistance with Multimeter This problem could be the injector is open internally or the electrical circuit or the driver that controls the circuit inside the ECM/PCM is bad , which means that a new computer would be needed . P0206 Cylinder 6 Injector Circuit Malfunction An I would get rid of those E3 spark plugs , Chrysler , Jeep an dodge vehicles don't like those, Cause running problems , check engine lights to come on etc...
Jul 14, 2016 | Cars & Trucks
How can I be sure if my PCM is bad???
I would try disconnecting battery again. Disconnect both cables and touch them together for a few seconds. This will reset all modules. Wierd that you had so many codes after just disconnecting battery. Sometimes very hard to tell if ecm is bad.
Dec 01, 2014 | 2006 Pontiac Torrent
What kind of trouble code is this and how i want to solve it.. help me!!
Hi, these are taken from the data sheets
P1523 - electronic throttle system (ETS) - throttle valve sticking - probable cause = mechanical fault, ECM
P0204 - injector 4 - circuit malfunction - probable cause = wiring, injector, ECM
P0206 - injector 6 - circuit malfunction - probable cause = wiring, injector, ECM
hope that helps
Apr 19, 2013 | 2009 Kia Carnival 2.5
2003 OUTLADER WITH MIS FIRE CODE, I CHANGED PLUGS WIRES COILS AND STILL GET IT AND YES IT RUNS ROUGH
sounds like it might be a fuel inj ,does it have a misfire code which cyl , try swapping fuel injs see if misfire changes cyls and follows fuel inj to different cyl
Sep 24, 2010 | 2003 Mitsubishi Outlander
2003 mitsubishi outlander died at stop light. wont start. turns over and has a full tank of gas. is getting fuel to engine.
very poss it could be crank sensor ,broken wire ? timing belt? advise installing scan tool that reads live data check eng rpm on scan tool see if shows eng rpm while cranking , poss remove upper timing belt cover make sure is turning and not damaged, poss computer related problem or power to eng systems would have to check for power at fuel injs and check for ground pulse with logic probe or led test light if crank sensor ok also check for spark at plugs with special plug tester and check codes first
Sep 14, 2010 | 2003 Mitsubishi Outlander
What does engine error code P0253 mean for an 2000 Intrepid
P0253 Injection Pump Fuel Metering Control "A" Low
Only way to solve is visit the your Injection Service dealer.
Jul 26, 2010 | 2000 Dodge Intrepid
Dead cylinders 2003 sebring
it sounds like you may have the wires on the wrong coil. It should be #1 on the #4 coil, and the #3 wire on the #2 coil. you probably have them backwards so 1 and 3 are firing on the exhaust stroke.
the firing order is 1-3-4-2.
they should be hooked like this.
Jan 23, 2009 | 2003 Chrysler Sebring
Computers & Internet Logo
David Payne
David Payne
