posted by sugapops on May 10, 2008
can this lens be used with modern digital slr cameras or onyl the old style manual slr? I wanted to see if it would work on a olympus e410 as i was given the samyang
Solution #1
posted on May 11, 2008
As long as the lens mount is compatible with the Olympus e410, you can use this lens.
It will only be limited by what features are supported through the camera body - I suspect that you will have to do everything manually.
Good luck.
Good luck.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Samyang 500mm f8 Ultra Telephoto
Email this problem
Email this problem
Can you Help with these Camera Lenses problems?
Repair Service
Find Camera Lense Repairman Near You:
