Question about Voigtlander Normal Nokton 50mm f/1.5 Aspherical Manual Focus Lens for Bessa R, Canon Screw Mount ...
I have a problem with a Nokton 50 1.1 that I have buyed new some month ago, from ten days the lens have a great problem of backfocus, we talk about 20cm with the subjet at 2,5m, it's impossible to use. I have already checked the finder of the camera and tested the lens on other Leica, it's a lens problem. How I can do? There is some tech. assistance that I could contact? (I'm in europe) thanks in advance Mauro Ruscelli PS do you know if exists, some tech schema of the lens, It's with floating elements or not? thanks
The lens has never defined focus on f 1.2, F.14, f2
Probably you have to check for front/back focus issue.
Nov 27, 2015 | Voigtlander Nokton 35mm f/1.2 II...
The manual focus seems not to be continuous, as approaching focus the step motor messes the focus to backfocus and vice versa.. !? I can turn the focus ring sometime focusing nearer and nearer but in some...
What kind of device are we talking about here? Actually, it doesn't matter, since this type of problem almost always requires servicing. Servicing or buying a new camera is always a process you have to make the call on. Get an estimate from a camera shop, and go from there.
Mar 04, 2010 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
No spark very intermittently
Ignition module. They tend to die an intermittent death.
Aug 08, 2009 | 1996 Ford Crown Victoria
What kind of problems are associated with cheap inverter welders?
Welllll, they are not on par with like a $1800 hobart... They will work for light stuff, but remember, when one part in the machine fails, you have lost all 3 machines at once. Myself, I buy good used expensive welding equipment for about the same price as new cheap stuff. I can get parts & work quality is great.
Apr 10, 2009 | Welding Tools
Olympus FE-230 Digital Camera Jammed
Turn on camera, makes grinding-type noise, then lens goes in and out several times...try to put your camera in a table lcd side down and turn it on...while lightly tapping on the sides of the lens. also try to check out this link
Nov 22, 2008 | Olympus FE-230 Digital Camera
WindowsInstaller not working
try to download it from here and install it.
May 18, 2008 | Computers & Internet
Canon 20D err 99 and shutter going off continuously
its not the battery
its the exposure of the shutter speed of the camera
it might need to be set manually. set it to 2.8 or 4.5 speed
i had the same problem when i bought my sigma 20mm-80mm lens.
the lens wasnt talking to the camera properly, it didnt know what it was aying about exposure speed rate.
put the camera in AV mode and set the speed rate.
the lens might be compatible with your camera even though it is a canon, or it could be defective
return and replace
Apr 21, 2008 | Canon EOS 20Da Digital Camera
Canon 400d constant backfocus
Backfocus problems will be magnified when using wide aperture lens with shallow depth of field, nice lens btw. Camera's adjustments for manual and autofocus are inside mirror cage behind mirror, and you dont want to risk getting dust on sensor or damaging sensor. Qualified camera repair shop or sending to canon for adjustment would be my suggestion.
Feb 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Nikon 18 to 70 AFS-DX lens focus erroers
I have never heard anyone mention a backfocus problem with this lens. In my experience, most of the backfocus issues that I have worked with to help people resolve have panned out as user error and/or a misunderstanding of the AF modes and performance of the camera. You sound like you know what's up, so that may not apply to may have a real issue. The best thing for you to do before proceding to having is service is test the lens thoroughly on both bodies to see if this is a consistent, reproducable problem or just an anomaly.
Jan 23, 2008 | Cameras
Voigtlander Normal Nokton 50mm f/1.5 Aspherical Manual Focus Lens for Bessa R, Canon Screw Mount ... Logo
81 people viewed this question
Top Voigtlander Cameras Experts
Are you a Voigtlander Camera Expert? Answer questions, earn points and help others
