Question about Business Objects BusinessObjects Enterprise (KNOWLEDGE)
A database error occured. The database error text is:(CS) "Driver not capable : Authentication", (WIS 10901) (Error:INF ) . While i was trying to generate reports from InfoView. O/S - Windows2k8 64-bit Operating System. Could you please help me how to resolve this issue.
Cs 3 activation problem
You will need to contact Adobe directly to resolve your authentication activation error.
Jun 29, 2012 | Adobe Computers & Internet
Driver installation error code 28 inf error
im receiving a error inf 28 on my mp3 sony walkman nwz-e344
Apr 25, 2010 | Sony Walkman Video NWZ-A816 Digital Media...
WIS 10901
Double check your filters or queries.
Mar 19, 2010 | Business Objects BusinessObjects...
No Audio Device
If the system is a GX260, then this is the audio driver
http://support.dell.com/support/downloads/download.aspx?c=us&cs=04&l=en&s=bsd&releaseid=R56339&SystemID=PLX_PNT_P4_GX260&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=0&libid=3&typeid=-1&dateid=-1&formatid=-1&fileid=67126
Feb 25, 2010 | Dell OptiPlex GX260 Intel Desktop PC -...
What is run time error '-2147467259(80004005)' how i solved it rewati nadan
"The Microsoft Jet Database Engine cannot open the file '(unknown)'"There are several causes for this error message:
  • The account that Microsoft Internet Information Server (IIS) is using (which is usually IUSR) does not have the correct Windows NT permissions for a file-based database or for the folder that contains the file.
  • The file and the data source name are marked as Exclusive.
  • Another process or user has the Access database open.
  • The error may be caused by a delegation issue. Check the authentication method (Basic versus NTLM), if any. If the connection string uses the Universal Naming Convention (UNC), try to use Basic authentication or an absolute path such as C:\Mydata\Data.mdb. This problem can occur even if the UNC points to a resource that is local to the IIS computer.
  • This error may also occur when you access a local Microsoft Access database that is linked to a table where the table is in an Access database on a network server.
Resolution
  • Check the permissions on the file and the folder. Make sure that you have the ability to create and/or destroy any temporary files. Temporary files are usually created in the same folder as the database, but the file may also be created in other folders such as the WINNT folder. For additional information about how to identify which folder does not have the correct permissions and how to configure temporary files, click the following article number to view the article in the Microsoft Knowledge Base: 253604 (http://support.microsoft.com/kb/253604/ ) Microsoft Access 97 database connectivity fails in Active Server Pages If you use a network path to the database (UNC or mapped drive), check the permissions on the share, the file, and the folder.
  • Verify that the file and the data source name (DSN) are not marked as Exclusive.
  • The "other user" may be Microsoft Visual InterDev. Close any Visual InterDev projects that contain a data connection to the database.
  • Simplify. Use a System DSN that uses a local drive letter. If necessary, move the database to the local drive to test.
  • Follow the instructions in the following article to work around this problem: 189408 (http://support.microsoft.com/kb/189408/ ) FIX: ASP fails to access network files under IIS 4.0 and IIS 5.0
Oct 16, 2009 | Microsoft Access 2003 for PC
I have a toshiba satellite a105-s4114. Did a fresh install and can't get the SD card reader to show up. I have gone to the Toshiba website and installed what should be the correct drivers. For the Texas...
INF error usually occurs if the inf file is missing or the auto run .inf extension file is missing. INF is used to load the auto run of the application that made it possible to be used to any specified application that serves its purpose. So therefore your SD card reader won't show up due to the face that its INF file that is responsible in loading it application is missing. So i recommend that you have to reinstall completely the driver of SD Card reader in order to be able to use the application.
Thanks
Aug 06, 2009 | Toshiba Satellite A105 Notebook
I don't remember my Server name ...thats why an error 53 of MICROSOFT SQL SERVER 2005 is being occured
As i had a problem of 53 in MS SQL server 2005....and i came to know my Server name by clicking on it Servertype that is given as Database Engine....so you could solve that solution too by doing this... This is a solution to the error 53..
.Actually, when you start your Sql server...it prompts you to enter the server name on "windows Authentication" and if server name is given by default,then its alright but if not, click on the given servertype i.e. Database Engine . By doing this, u could find ur Servername.
Jun 10, 2009 | Microsoft SQL Server Standard Edition for...
I can't connect the ms-sql database with flex
It sounds like you don't have the proper authentication to access the SQL server from the error code you are receiving. I would ask you SQL DBA to check on the permissions within SQL and verify that you have the proper access rights to the database you are connecting too. It is SQL throwing that exception error...
Cheers!
J the Guru
Jun 27, 2017 | Microsoft SQL Server 2000 Standard Edition...
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Open Questions:
See all Business Objects BusinessObjects Enterprise Questions
Computers & Internet Logo
845 people viewed this question
Top Business Objects Computers & Internet Experts
David Payne
David Payne
Are you a Business Objects Computer and Internet Expert? Answer questions, earn points and help others
