You will need to take the front panel off, there are screws inside the dryer door, may be two on each bottom corner, and with a screwdriver gently pry up on the top corners as they are clipped in. Then you will have to unhook the door switch. remove the front panel you will need to look at the back top of dryer and make sure there are no screws that are holding the top down, lift up on top of the dryer and it will rest in the up position on the two brackets, the coil is located in the back right hind side an will look like a extended spring. You might want to remove the back upper plate of the dryer as there is usually a diagram in there, of course remember to unplug dryer before working on it. Hope this helps tim
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
