Question about Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800c Yellow Toner Problem: I have one of these machines complete with the scanner/copier top fitted. For the past three years the machine has given faultless service and only ever needed standard consumables replaced like toner cartridges, all developer units and photo conductors which is part of the costs of ownership. It has now decided to throw me a problem. it keeps reporting the yellow toner is empty when it clearly isn't, I have tried another replacement cartridge thinking the cartridge may be faulty but no change. I have dismantled the covers and vacuumed the toner supply tubes by disconnecting them there appeared to be a clot in the pipe toward the drum end where it fits onto a cogged motor/pump thingy. After doing this I am still getting the original yellow toner empty message and now thumping my head against the wall! Where is the toner pump located and how do I test it? ...or can anyone suggest any thing else as after vacuuming out the tubes I did not do a forced toner supply as I was unaware of this procedure. Please bear in mind the machine is operated from the scanner top panel and not the small control panel on the actual printer as this seems to be bypassed due to the scanner top being fitted. Any help would be greatly appreciated.
    Problem Solver:
  • 6 Answers
Hello there, i have the same problem here, but in the black
toner, i did the same as you and look that we have a clogged
pump or bad pump, the pump is located exactly where the dev.
unit is, but to remove it we need to take the laser unit from
the top cover where the printed pages stack, i'm going to work
in my printer, i let you now if i'm able to unclogg the pump.
I,m a electronic techniccian for Arcade machines(Namco) is the
first time that i work with a laser printer, the pump price is
$171.00, i let you know. Thanks
Miguel
Posted on Sep 09, 2010
Why my printer Aficio SPC 221SF don't print magenta and yellow colours
Could be faulty toners or clean contact points on the toner and machine
Mar 22, 2016 | Ricoh Aficio SPC221SF Multifunction...
Ricoh AP3800C sc389 error code
SC389 is a development gamma error in the magenta. There can be several causes for this error - a toner supply problem, incorrect toner used, a laser exposure problem etc. This is not likely to be an easy problem to fix unless you are experienced in such matters, so you may need to look for someone who can help out.
Mar 25, 2014 | Ricoh Aficio AP3800C Laser Printer
How to enter service mode for ricoh mpc 3003sp
YOU NEED TO PRESS C BUTTON(RED) LATER PRESS KEY 1 , KEY 0 , KEY 7 & HOLD THE YELLOW KEY FOR SEVERAL SECONDS, THEN THE MACHINE WILL ENTER SP MODE
Sep 23, 2013 | Ricoh Aficio AP3800C Laser Printer
Printer does not load toner
the toner tube could be clogged -big and messy job
Jan 07, 2010 | Ricoh Aficio AP3800C Laser Printer
Error message - Reset Oil Fuser Unit Correctly
The fuser oil sits on top of the fuser and has silver contacts on it. Sometimes the contacts in the machine get bent. Turn off the printer and check the contacts and if bent use needle nose pliers to make straight again. Make sure the contacts on the fuser oil are not drity.
May 27, 2009 | Ricoh Aficio AP3800C Laser Printer
I have a Ricoh 2045E I changed the toner and now get a SC680 error?
There are no SC 680 codes listed in the service manual for a 2045e
Please re check the code
Feb 26, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Copier C3500 error sc553
dirty toner on paper top after printed
May 22, 2008 | Ricoh Aficio AP3800C Laser Printer
Color adjust error
problematic machine. transfer belt damaged(white spots ) for temp fix try manual registration from menu
May 09, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
248 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
