Question about HP Compaq nc6000 Notebook
Smart card error ,my laptop is not boot even by pressing F10 key
  • 54 Answers
If you are having the s.m.a.r.t hdd error you can press f10 and f8 all you want the hdd is gone btw f10 is to change the boot sequence
Posted on Sep 02, 2010
I've got a dc7800 Small Form Factor system. After less than a second, a blue window"smart card authentication" and below that, "smart card reader not present".
"System Options Not Set" normally means that the battery that maintains those options has gone dead. That's usually a 2025 coin cell on the motherboard.
I would replace that first thing, then set the BIOS options. Usually, there's another message that comes up, "Press F1 to continue, F10 for setup". F1 will let you system boot, most likely, but doesn't set the options. F10 (or whatever it says) will get you to where you can set the options.
Nov 09, 2015 | Computers & Internet
How do remove smart card Authentication errors in my hp compaq?
Try this Press F10 and change the security settings to remove the need for the smart card to login. This will eliminate the authentication errors associated with the faulty card.
See this web page on how to do it. HP Compaq dc5700 Business PC Computer Setup F10 Utility
Feb 16, 2015 | HP Compaq d530 SFF PC Desktop
What or is there anything I can do to get past a smartcard message?
Is the message after Windows boots up? or before you even see a windows logo?
Smart card security is an alternative way to secure a laptop. The nc4200 has a BIOS setting for removing it, however you need an approved smart card to get in to change that. Sounds like you wasted your money if that is the case.
If the laptop actually boots up, I would recommend doing a system recovery. More info here: http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/setupInstallResults/?sp4ts.oid=447354&spf_p.tpst=psiContentResults&spf_p.prp_psiContentResults=wsrp-navigationalState%3Daction%253Ddoclist%257Ccontentid%253DH.02.06&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
May 03, 2014 | HP Computers & Internet
My notebook HP compaq nc 8230 dont start, only write : INSERT SMART CARD INTO READER ...what should i do??
you need to log in to the bios once you have restarted the pc either by pressing f2 or del button thenlocate where the boot option is to change it to hard disk then cd drive etc then press f10 to save the settings and restart to try again if it will boot
Sep 21, 2011 | Computers & Internet
My compaq NC6220 prompts me to insert smart card into smart card reader when booting.
The boot order is incorrect - it lists the card reader as the first option. Go into the BIOS (F10 during boot) and change that: put the CD_ROM first followed by the hard disk.
Sep 09, 2011 | HP Compaq nc6000 Notebook
Please Insert Smart Card
open slat and re insert the sim card .also check your setting
Apr 10, 2011 | HP Compaq nc6230 Notebook
Error Code 1802 after installed mini wireless pc card. Contacted fixya earlier today done what was suggested, now laptop won't boot into Windows xp at all. Keeps doing check disc over and over.Got...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
error 1802
go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software
hope this helps
Jan 22, 2011 | Computers & Internet
Insert smart card into reader problem
I think its looking for a boot command from the card reader. Which means pressing the DEL or F10 or F2 key repeatedly while booting to get into your bios to change your boot order.
If it wont let you, try booting while pressing the F8 key, with luck it may bring up windows boot options, choose the safe mode. When up, Click on Start - all programmes - accessories - system tools - system restore - choose a date prior to problems. (This is for XP, Vista and Win7 slightly different)
Boot from your windows disk, and choose the repair option.
Or download, UBCD4Win , the ultimate boot cd for windows, This will load a windows shell system with loads of diagnotic and repair tools.
You could download and run Ubuntu without installing, that will give you access to any data files.
If none of this works, the only recourse is to re-install windows. But in
doing this, you will be re-formatting the hard drive which will remove all data on the drive.
If you don't have a copy of windows, you do have Ubuntu. I use it nearly all the time now, even though I have a dual boot system.
Jul 21, 2010 | HP Compaq nc6230 Notebook
My laptop HP Pavilion dv1000 is not working so I pressed F10 for the Bios Setup Utility went to tools to do a Hard Drive Self Test and the Test Status is #1-07 Fail. What does that mean?
Hi there.
The error code means the drive has failed or that Self-Monitoring, Analysis, and Reporting Technology, or S.M.A.R.T is faulty.
Go back into the bios and disable the
S.M.A.R.T, hit F10, save the changes and try to boot again.
Please post back with the results.
Good luck
Jun 08, 2009 | HP Pavilion dv1000 Notebook
When i boot up i get a message that my hard disk failure is immenent is there anyway to repair this problem
if you get a "Disk Controller Error" error messages that may occur before Windows XP or Windows 2000 is started. Imminent Hard Disk Failure This error may appear when the hard drive detects that it will fail or stop working sometime soon.
Backup Data Before Proceeding Although the notebook may continue to start Windows after displaying the message, it is advisable that you immediately backup your personal data from the PC by copying it to a Network Drive, CD, DVD or USB storage device. After completing the backup, use one of the following methods to resolve the error. Step 1: Test the Hard Drive Use the steps below to test the hard drive in a Notebook PC using the HP Hard Drive Self Test.
  1. Plug the AC Adapter into the Notebook PC.
  2. Press and hold the Power button for 5 Seconds to turn off the PC.
  3. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
  4. After the BIOS Setup Utility is displayed, use the Right Arrow key to select the Tools menu.
  5. Select Hard Drive Self Test
  6. Press the Enter key to start the test.
The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed. If any test fails , order a replacement hard drive. If all of the tests pass, the hard drive is not damaged.
If all tests pass , press the power button to restart the PC. The error was most likely a result of a shock to the PC triggering a SMART error from the Hard Drive. Since the Notebook PC passed the Hard Drive Test, it is safe to use.
Mar 07, 2009 | Acer Aspire 3680 Laptop
HP Compaq nc6000 Notebook Logo
75 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
