Question about Systemax CAT6 Patch Cable
How to crimp without tools - Systemax CAT6 Patch Cable
    Sergeant:
  • 284 Answers
Without tool means imperfection to ur work?? but still u can but safely pressing each and every copper out in new jack which just while crimping cut the shield and connect to the copper in that shield and give the connection.But not perfect way of crimping??like scratching ur head??
Posted on Sep 02, 2010
My radio sound just stopped working, everything else was fine so I've come to check my connections and the one of the ISO plugs which controls the speakers is faulty but I don't know what side.. The pins...
If it were mine, I would just crimp the wires together and do away with the plug altogether. You could try using some lithium grease but that probably won't do much good. Go with the crimps. A cheap crimping set with crimps and tools are easy to find at $10 or less. Just crimp the wires as they are connected at the plug.
Feb 26, 2015 | Audio Players & Recorders
Tip
Broiler element does not get hot enough.
I did some work recently on a free-standing electric range.
The broiler element was heating up just a little. It was not getting red hot.
The range was practically new.
I discovered the crimp-on spade terminals to the broiler element had lost their springiness and were not making good contact with the element terminals. The ends of the wires going to the broiler element also showed signs of excess heating due to resistive contacts.
I bought a pack of new, high temperature crimp terminals at the appliance parts store, stripped the wires, and crimped the terminals on.
The original crimp terminals were right-angle. The new crimp terminals are straight. I didn't have a specialized tool for right-angle crimps. The straight crimps worked fine.
Just make sure there's plenty of clearance between the rear cover and the wires coming off the crimps to the Calrod.
Broil element now works great.
By the way, other ranges I've worked on use screw-on terminals instead of press-fit spade terminals. Not sure if press-fit spade terminals hold up after many years of service.
Maybe if an emergency repair needs to be done, could try drilling a hole carefully through the assembled spade terminal and putting in a 4-40 screw to recover the contact without having to buy replacement terminals.
on Jul 14, 2014 | Kitchen Ranges
Hack user password
If you want to connect all pc together then you can use a unmanaged switch or managed switch if you know to configure it. You will need lan wire and crimping tool. Without proper knowledge of networking you can't do it. Please find knowledgeable person to do it. Thank you for asking on fixya.com
Apr 25, 2014 | Connectify Computers & Internet
Tips on how to fix rj45 connector problem
Replacing the Patch cord is the easiest thing to do. If it is crimped on to the cable coming out of the wall, you should put a jack on it. To replace the clear mod plug on the end, you need another Rj45 mod plug and a crimp tool. These can be purchased at Home Depot, Graybar, Fry's electronics, Radio Shack etc. The crimp tool can be a little expensive but if you are going to need to do any more in the future, you'll have what you need. If you decide to put a Cat5e or Cat6 jack on it, they too can be purchased at the places mentioned above. You would need a punch tool instead of a crimp tool. Some jacks are tool-less but that is not the norm.
Mar 08, 2014 | 3Com NBX 3102 IP Phone
Wilson roof mount coax is broken at radio connector end
I'm going to assume you've got a PL-259 connector on the end of the coax cable - they look like this:
They are designed to screw onto the radio's RF / Antenna jack. The end shown is standard, the other end - that the cable enters, requires an insert that matches the coaxial cable outside diameter.
There are two versions of the connector; solder-less and soldered. The best connection is provided by the soldered type. It is superior both electrically and mechanically to to the solder-less version. If you lack soldering skills, patience and / or the tools and supplies to solder the connector, the solder-less version will be the way to go.
There are two types of solder-less types, a crimp and non-crimp type. They look like these:
The "Non-crimp" solderless PL-259 from Radio Shack - about $6.
A crimp type PL-259 connector - $2 and up at various radio & electronics stores.
Since this end of the antenna is at the radio and presumable protected from the elements, it may prove to work very well for you. Each of these connectors requires knowing the type cable (RG-58 and RG-8 are very popular types - but there are many other 50 ohm coax cables) or outside diameter and selecting the one that fits correctly, along with a crimping tool (and dies) for this particular connector size. You may get by with a standard pair of pliers, but the connection is not as good as would be obtained with the crimp tool. Generally, you would provide a crimp around the ferrule at the cable end for the braided conductor and another at the very tip of the connector for center conductor.
Each connector will include very specific cable preparation steps for the removal of insulating jacket, braid and dielectric material to provide proper fit of the connector to the cable. If it were a "standard", I would have included it.
Check this link for Youtube video the show how to install the various types of PL-259 connectors on cables.
I hope this helps & good luck!
Jun 05, 2012 | Radio Communications
How to fix the Ethernet plug
The broken ethernet plug on the cable can be cut off and a new one can be crimped onto the cable. You need a special crimping tool and the wires needed to be arranged in a specific order in the connector.
If you do not have the skills and the tool then I recommend you purchase a new cable.
Mar 24, 2012 | Computers & Internet
I need the line that goes between the master cylinder and slave cylinder for my 1992 jeep wrangler and cannot find the part anywhere..any ideas?????
any parts store will have steel and flex hoses of differing lengths and sizes hanging on the wall for brake and clutch lines. you need someone to measure, make, and bend the line and install it for you.
takes a tool to flare the ends and bend without crimping
Jan 31, 2011 | 1992 Jeep Wrangler
I need to install a pioneer deh-p6600 in a 95 rodeo.
you only need 2 things and a few tools and tape or crimp clips and crimp tool, 1. installation kit for that year and make, 2. wire harness for that year and make. then all you have to do is follow the colors on the harness and radio harness, yes they are color coded.
Jan 10, 2010 | Car Audio & Video
Ethernet cable end repair
Unless you have a RJ45 crimping tool you are stuck with having to ask someone who does have one to borrow it, honestly if you know someone with a crimping tool then ask them to perform the repair.
If however you have the tool for a straight through cable (most common)
Holding the plug upside down (catch towards the floor) and the pins furthest away from you I use the following layout;
orange white (furthest left hand side)
orange
green white
blue
blue white
green
brown brown white (furthest right hand side)
slide the cables into the plug held in the position describe above, then check the order of each wire once more using the crimping tool to "crimp the new RJ45 connection in place.
Basically as long as you hold the rj45 connector in the same position the wires should go into the same corresponding position at each end.
Nov 08, 2008 | Belden 1000 ft. UTP Network Cable
Coalial TV cable
If you mean the plug on the end of your incoming cable line that connects to the back of the TV or cable box, Radio Shack sells replacements. You can get crimp-on ones (a good mechanical connection but requires a crimping tool, not expensive) or ones that twist onto the cable without special tools. If this is a connector on the end of a cable between a cable box or VCR and your TV, just get a new cable and don't worry about repair.
Jun 30, 2008 | Televison & Video
Systemax CAT6 Patch Cable Logo
592 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
