Question about Thomson LCDB 03B 27 in. Television
My tcl tv always shutdown every 10 sec with the blue screen keep appearing.what should i do?help.
PLS TXT ME.I CAN HELP
Posted on Jan 04, 2011
  • jhimdrummer Jan 04, 2011
    U CAN SEND ME EMAIL,I WILL HELP YOU
My tv tcl 21k77 stuck in standby mode if i press
Sounds like a power pack issue. Might be the switch mode transistor not working correctly. Either try repairing it or take it to a local tv repair centre
Oct 14, 2014 | Televison & Video
My TCL TV has a blue screen saying no signal. What button do I push on my new universal remote to get my cable tv
the button will be labeled either source, input, tv/video. if the direct TV remote was programmed for your television there is a tv/input button
Nov 03, 2013 | Televison & Video
Tcl tv screen
T'Con board is faulty. Should be replaced.
Apr 30, 2013 | TCL L32D20
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
Hitachi 65f59 65 TV keeps shutting off
This set uses a number of green L.E.D.'s inside which are tied to different voltages---if you can watch them when set shuts off you are looking for one that goes out either quickly or after the others--points to area (voltage) where problem may be.
Other visual indications are screen changes red, green, blue right at shutdown and sound and brightness then both vanish=shutdown circuit being triggered to protect the set.
May 15, 2012 | Hitachi Televison & Video
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
I have A TCL-21189U TV when Ipowering it on rainbow color appears and within a secod it shutdown..... Can you help me find it trouble since I have a little experience in trouble shooting TV's
This is high voltage inverter fault. Usually this is the high voltage transformator fault that is connected to the LCD lamps. It must be replaced.
May 16, 2011 | Televison & Video
I WANT CIRCUIT DIAGRAM FOR TCL TV MODEL-21276N
My TCL 21E20,,when switch on, giving vertical line on the screen for about 3 sec. and then switch off again.
Jan 03, 2011 | Televison & Video
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
Tv problems
Unplug the three red-blue-green plugs nest to the convergence amps. If the unit powers up and stays on the picture will look bad but will confirm that the convergence amps have failed...
Replacing the amps and one or more resistors in the yoke return will restore the set to normal operation..
Use only Sanyo original Ics..
Bill
Oct 11, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Thomson LCDB 03B 27 in. Television Logo
210 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
