Question about Sony FD Trinitron WEGA KV-SW29M50 29" TV
Sometimes right after I switch it on, and sometimes after several minutes of normal functioning, the red standby light starts blinkig and the language menu appears on the screen. Also sometimes it changes rapidly and randomly to AV channels, all by itself. It does not respond to the remote control while all these happen. I put the batteries out of the remote control in case that it was responsible for the above mentioned problem, but it still happened. I can only press the power button on the TV to turn it off. Please note that the TV is approx. 8 years old.
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
SOURCE: remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Posted on Oct 26, 2007
SOURCE: set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Posted on Aug 08, 2008
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
skaterkid307
  • 86 Answers
SOURCE: tv doesn't respond to remote controller
This is caused by radio frequency and what i mean by that isyour tv unit is gettng confused with the crystals that control the connection between the tv and remote.The solution to this is to go to wal mart and buy a new universal remote and in the package should be an instruction manual to set the remote to the tv , First find your tv name in the pamplet,second there will show a code of the remote type it in and enjoy.
Posted on May 18, 2010
Panasonic PTL500 LCD HIDEF projector - Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
The bulb is a discharge type - it needs a very high tension to work. The role of the ballast board is to convert the low voltage DC current coming from the power source in a high tension DC current for the bulb. Unfortunately you were truly unlucky : when the ballast board died it sent a high tension surge thru the power source and from there at the other components on the mainboard - the processor couldn't handle it and got fried. So now when you try to start the projector this is what happens: the power source starts normally - the status light goes to green as it should; it functions normally so it powers the ballast board and the rest of the mainboard - the ballast works so the bulb lights up; the mainboard on the other hand remains dead because the processor is dead so no sustain signal is sent to the power source; without the sustain signal the power source goes, as it should , in an very normal stand-by - the status light goes to red.
The entire mainboard will have to be replaced - you can't replace just the processor, it's glued in there. This is going to be expensive so ask a quote before doing it.
Dec 23, 2010 | Televison & Video
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Dec 22, 2010 | Televison & Video
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Model RE44SZ21D when I switch TV on it maks a whinning sound like a hard drive not reading properly and switches back into standby. Sometimes it will start, (normally if not tried for sometime) stays on...
hello john.
this is a late suggestion,but if you still have the set & the proplem
in existence.
then i suggest you check with the lamp---situated on the right hand
side ,two screws to undo--once in further two screws--pull back the
casing clean with a dry cotton cloth & with that clean the cooling
fan just adjasent to the case.+ remember to leave the tv on standby mode for 3 minutes before you completely switch it off ,as this helps to cool down the lamp the fan at rear still propels while the tv is in standby mode.--------ASH
Aug 14, 2008 | Televison & Video
Flashing red light
sounds like a flaky power supply or lamp ballast
Jun 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
Sony FD Trinitron WEGA KV-SW29M50 29" TV Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
