Question about Refrigerators
Hi , i have an lg fridge model no gr-5392gc , serial no (204kr00305) an i am wanting to install a heater part to the freezer section of the fridge part no (5300jb1088). i was wondering if someone could send instructions on how to do this please.
  • 1 more comment
  • john ewing Sep 02, 2010
    actually its the black cord that i wanted to know how to install (part no canaan,
    5300jb1088)
  • john ewing Sep 05, 2010
    hi thanks for your help but still not sure if we are talking about the same part ( heater sheath) was wondering if it fits around the silver thing with the little fins on it? would you be able to send some pictures with instuctions on how to install, it would help alot. thankyou.
  • john ewing Sep 06, 2010
    ok so the black heater sheath fits all the way around the silver evaporater coil, is it allowed to touch the evaporater coil?. does the coil hook in the back of the freezer, an does it sit down in the silver lining part ? i didnt take it apart thats why i am not sure how to put it back together.
  • 857 Answers
Follow the steps mention below:
Before you begin to replace your defrost heater, make sure you disconnect the appliance's power supply. The easiest way to do this is to unplug the unit from the wall. Alternatively, you could trip the appropriate switch in the circuit breaker panel, or you could remove the appropriate fuse from your home's fuse box.
Consult with an appliance repair technician if you do not feel you have the skill or the ability to successfully complete this repair.
Locate your defrost heater. It can be located behind the back panel of the freezer section of your refrigerator, or under the floor of your refrigerator's freezer section. Defrost heaters are commonly located beneath a refrigerator's evaporator coils. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.
The panel you need to remove may be held in place with either retainer clips or screws. Remove the screws or use a screwdriver to release the clips holding the panel in place. Some older refrigerators may require that you remove a plastic molding before you can gain access to the freezer floor. Exercise caution when removing the molding, as it does break fairly easily. You could try warming it with a warm, wet towel first.
Defrost heaters are available in one of three primary types: exposed metal rod, metal rod covered with aluminum tape, or a wire coil inside a glass tube. Each of these three types is tested in exactly the same way.
Before you can test your defrost heater, you have to remove it from your refrigerator. A defrost heater is connected by two wires, and the wires are connected with slip-on connectors. Firmly grasp these connectors and pull them off the terminals. You may need a pair of needle-nosed pliers to help you. Do not pull on the wires themselves.
In addition to the two wires, there may also be some clips or screws holding it in place. You will have to release any clips or remove any screws before the defrost heater can be removed. If your defrost heater has an outer glass tube, refraing from touching the glass with your bare fingers. It is possible for skin and/or oil from your fingers could cause the heater to burn hot. This could result in damage to your freezer and/or your heater. If you do happen to touch the glass with your bare fingers, clean it with rubbing alcohol and a clean cloth or paper towel.
Install the new defrost heater and reconnect its wires. Replace the access panel you may have had to remove. Restore power to your refrigerator.
Posted on Sep 02, 2010
  • Refrigerators Master
  • 1,711 Answers
To remove the defrost heater:
a) Remove the two hex-head screws from
the evaporator fan motor shroud.
b) Lift the evaporator fan motor shroud
and disconnect the evaporator fan motor
connector (see the photo to the left).
c) Unclip the bimetal from the evaporator
inlet tubing.
d) Disconnect the terminal connector and
the two defrost heater wires from the
harness connector.
e) Remove the evaporator fan motor
shroud and the two side foam blocks.
f) Remove the hex-head screws from the
right evaporator cover mounting bracket
and remove the bracket. Be careful not
to drop the screws down the drain hole
at the bottom of the liner. Cover the hole
with a cloth.
g) Remove the foam block from the right
side of the evaporator.
NOTE: Be very careful not to over-bend
the refrigerant tubing.
h) Lift the evaporator up slightly and unhook
it from the liner, then pull the
bottom of the evaporator toward the
front of the unit.
i) Bend the two hangers at the bottom of
the evaporator.
j) Unfasten the two metal clips from the
right side, and slide the defrost heater
down and off the evaporator.
Now is free to remove down all the way.
You can follow in reverse order to install the new heater.
  • espressonist
    espressonist Sep 05, 2010
    You are in the correct direction, the silver thing with little fins on it is the evaporator and the heater fit around it just as you figure it out.
    The heater it can get out if you unsecure it and pull it all the way down.
    The new one can put back in reverse pull it up from the bottom with the two electrical ends on the top.
    It is simple as idea but it needs skills good hands and patient.
    Sorry we don’t have any photos available.
    If you just need anything more just comment back
  • espressonist
    espressonist Sep 06, 2010
    Yes this is the purpose of the heater to contact with fins so they will warm up and melt the ice in the faster way.
    Evaporator coil it is hanging on the back but it does not sit down in order the fins to have a space all around so the air to flow free around it and also the melting ice to be free to flow out from the fins.
    The best solution for you to be secure that you will remember to put it all back together is to take some photos each step you go so in any case you forget about something to have them as reference this is a very helpful method.
LG serial#GR L247NIS is making slow ice
Have you checked the temp in the freezer section? Should be near zero F - at least below 10 F. You would also be noticing ice cream being soft.
Feb 19, 2018 | Refrigerators
I have LG Electrocool GR-252SQ(Double door).the freezer is very cool but the lower fridge section is not getting cool.Plz guide.
i have same fridge and my problem is that the water from freezer is not going out pf the fridge, instead it comes down to fridge section through condensation
Mar 24, 2013 | Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Jan 23, 2009 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
