Question about Aloha Housewares (93645) Ceiling Fan
Model 79758; went to bed with ceiling fan on,woke up with fan blades not moving and motor humming. Fan is 4 months old! What gives???
  • 3,083 Answers
Obviously, the motor shaft is either broken or loose. Sounds like poor quality to me. Complain to the manufacturer- this item should last for years, literally. Here's their web site:
http://www.macraesbluebook.com/search/company.cfm?company=1133220
You might take it apart to see if you can tighten, glue, or fix it.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 02, 2010
  • texaspiglets Nov 03, 2010
    Ours just did the same thing, only it's 5 years old. What do you do if you don't know how to take the motor shaft apart? The lights still work.
I have a Hampton Bay ceiling fan Model BC552. light works, but fan does not. there is vibration (hum) when fan motor is switched on, but fan blades do not move. Blades rotate freely.
Start up capacitor is likely bad. That's the rectangle thing in the bonnet with two wires. If you replace it, replace the on/off switch at three same time.
Oct 10, 2017 | Hampton Bay Dryers
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    Daughter was shaking out her bed sheet when it hit the ceiling fan and all the lights went out, looks shorted. Do I need to buy a new light unit?
    no, you don't need to buy another unit as long as your ceiling fan motor still in good condition. most probably the cause of the blackout is the overload of the fan motor when the fan blades entangled with the sheets and it trips the breaker due to over current.
    if your fan still runs by now then it is ok. to be sure, have it checked for a qualified person.
    Dec 29, 2010 | Hampton Bay 24002 Ceiling Fan
    The ceiling fan hums but the blades dont move when turned on
    Your fan motor went bad. Cheaper to replace fan than repair motor.
    Aug 18, 2009 | Dryers
    Blades will not turn
    The motor probally damaged while you are moving the fan to the new house.
    Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
    Ceiling fan
    If the fan blade mounts are removable, go to your local hardware store with one of the mounts, and find some screws that will fit. You might not be able to get the same color, but if you check a few stores you should find something with the right shape of head to fit snugly.
    Apr 17, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
    Ceiling fan power
    It sounds like the fan motor has blown out. Is this an old fan? The motors do burn out every 5-10 years, depending on the brand and quality of motor.
    Apr 14, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
    Ceiling fan
    There's a rubber circle that is the damper between the blades and the motor shaft that rotates. The circle has spokes connecting the outer ring, which the blades screw into, to the inner ring which attaches to the shaft and holds it. If the spokes break you get the symptoms you describe, motor hums but no rotation, but blades can turn manually if you hand turn them them. If this is the case you need to remove and replace the blade mounting ring/damper. (About 25 bucks online)
    Apr 27, 2006 | Hunter Sontera 52" Ceiling Fan with...
    Aloha Housewares (93645) Ceiling Fan Logo
    105 people viewed this question
    Top Aloha Housewares Dryers Experts
    Mike Carew
    Gene Haynes
    Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
