Question about Sony VAIO PCV-V100G (PCVV100GKIT1) PC Desktop
How to install 1 gig ram - Sony VAIO PCV-V100G (PCVV100GKIT1) PC Desktop
  • 4,281 Answers
If you have want to connect RAM more than 1 RAM then first make sure all RAM has same frequency . So they are not incompatible with eachother. Then open cpu cabinet then you can see RAM on motherboard Connect 1 GB RAM on mohterboard then you can use it. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Sep 02, 2010
K9N6SGM-V I have a 2 Gig ram and i installed a extra 1 gig so its 2gig + 1 gig = 3 gig .and my computer wont boot
some types of ram are not comatible with othres always try to keep them ofthe brand /type
the larger ram should be in the socket closest your CPU central processing unit
if these are not requirements are not followed your comuter willfail to boot
hope this helps you
Oct 06, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Jetway motherboard 939 GT4-SLI-G will only accept 3.5 gig RAM and not 4 gig RAM as per specifications. It does not run on gaming applications when 4 gig inserted (4 x 1 gig). Any solution?
If you are running a 32 bit version of windows it will only see up to 3.5gig of ram in your system no matter how much ram you put in there.
This is down to 32 bit windows only being able to address a maximum of 3.5 gig of ram.
Windows 64bit can address a far larger amount of ram and is why you will see all windows computers running 4gig or more of ram having Windows 64bit installed.
As you have said your computer is running Windows 7 32bit the only way you will get your computer to see the whole 4gig of ram you have installed is to upgrade to Windows 7 64bit.
Hope this answers your question and helps you out.
Jan 18, 2011 | Jetway 939GT4-SLI-G Motherboard
Can I install one (1-gig) memory stick instead of 2 match pairs (only have one) this is to replace two 256 sticks?will it preform at 1 - gig memory
Yes.
The Maximum Total Amount of Ram Memory is 2GB.
(2048MB)
The Maximum Amount for EACH ram slot is 1GB.
(1024MB)
Ram should be installed in Slot 1, when using just one stick of ram.
This is the ram slot closest to the Processor.
The Processor reads ram memory that is installed in Slot 1, first.
This is Dell Support, and the main support page for the Dimension 3000 desktop computer,
http://support.dell.com/support/edocs/systems/dim3000/en/SM/index.htm
In the list left-click on - Technical Overview
Now click on - System Board Components
Number 1 is Slot 1.
Note*
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate computer hardware components inside a computer.
Work on a table.
After you have opened the computer case, and BEFORE you remove that ram module from it's anti-static protective bag, TOUCH the metal frame of the open computer case. (Power unplugged from computer)
This will relieve your body of static.
Ignore the above if you are already aware.
May 21, 2010 | Dell Dimension 3000 PC Desktop
Intalled 2 - 2 gig Ram bios is only reading 3.
Hello.
I believe the ram needs to be on seperate channels to work.
Giving you a link to a supprot manual.
Good luck.
http://www.fixya.com/PostAnswer.aspx?thid=3880661
Jan 13, 2010 | Computers & Internet
I have 1 gig ram added 2gig of ram to my P5VDC-MX mother board.
Your system might only be able to recognise 2gb of RAM. Tiger Direct has a RAM finder for almost every computer. Check it out to see if you have too much.
Jul 02, 2009 | ASUS P5VDC-MX Motherboard
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
4gigs ram
Switch sticks around in various combinations (2 gig in slot one, 1 gig in slot two, switch, try other stick, etc) and see if it is the memory or the motherboard.
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Jan 17, 2008 | Compaq D310 (287944-CTO-4) PC Desktop
Ram upgrade
In order to see how many MHz is your desktop, please right click on your "My computer" icon and select "Properties" from the menu.
It will open the system properties window. select the tab "general" and you will see how many MHz is your desktop.
If you have found this solution helpful please rate it as "solved", otherwise please ask here again.
Thank you :)
Oct 12, 2007 | Computers & Internet
Sony VAIO PCV-V100G (PCVV100GKIT1) PC Desktop Logo
79 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
