Question about Steinberg Nuendo 3 for PC
Nuendo has stopped working on startup error on windows 7
2 Suggested Answers
anil_valayil
  • 218 Answers
SOURCE: nuendo 3 not working in windows 7
Looks like you may have to run your windows 7 in XP mode to get this working. Nuendo 4 seems to have latest windows compatibility. However, it would worth checking whether the latest version they say is vista or windows 7.
Posted on Jan 29, 2010
How will nuendo 3 work on window 7
please use nuendo 4 instead of 3
Oct 12, 2014 | Computers & Internet
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Inspiron 5110 slow startup
Assuming you are using windows 7...in the run window type msconfig
After the window opens up, click on the startup tab and uncheck anything that you don't want to start automatically when windows starts. Becareful in here though, you can disable your windows if you aren't careful. You may also want to run your antivirus to make sure that nothing is hogging your resources at start.
Nov 23, 2012 | Computers & Internet
Windows 7 64 bit Ultimate SP1. Nuendo 4.2.3. 32 bit version. Delta 1010 LT Sound card. Just out of the blue I started hearing slight crackle when playing back videos, wav files etc etc. It seems to do...
you might have to remove the sound card and make sure the socket is free of dust restart your computer then reinstall it
windows 7 should automatically find the drivers and install them
click start right click on computer select properties in the left hand panel device manager scroll to
sound and video game controllers if you see a yellow qustion/exclamation mark ? ! or a red X
a newe driver will need to be reinstalled
hope this will help
Sep 25, 2011 | M-Audio Delta 1010 Sound Card
Hi.while installing win 7 ,after seup Nuendo 3, encouner with an error which means nuendo runtime.....any way nuendo 3 doesnt work . I downloaded the latest Elicencer and install it but the problrm still...
Buy it or read the Terms of Service. We do not help with
"By using the Site, you agree heartily not to do any of the following: Publish on this Site any materials, including questions, comments, suggestions, ideas, plans, notes, drawings, original or creative materials or other information, provided by you either in the form of e-mail or submissions to FixYa, or postings to or on the Site ("Content") that is unlawful [...]"
If you did buy it, then the activation code may be on the box or in the manual.
Jul 18, 2011 | Steinberg Cubase 4 ( Windows / Macintosh )...
I need a driver for my Nuendo 96/52 PCI Card. I need it to work with Windows 7 64 bit.
http://www.rme-audio.de/en_downloads.php
Your product is listed under "Hammerfall DSP" as "Digiface" and "Multiface".
Mar 02, 2011 | Intel Steinberg Nuendo AudioLink PCI 96...
Recently bought & installed Roxio 2011 on Windows XP and it worked fine. Upgraded laptop to Windows 7. Roxio stopped working. Uninstalled all Roxio programs and reinstalled Roxio Creator 2011. No...
If you are getting the error at startup, roxio service might not started or disabled. What you can try to do is to enable all roxio service. refer to the steps below.
- click start > run - type services.msc - look for all roxio service i.e roxwatch.db - double click it then select the startup type to automatic - save the changes then restart computer
Cheers . . .
Feb 02, 2011 | Roxio Creator 2011
Stop:0x000000A5 (0x0001000A, 0x00000000, 0x00000000, 0x00000000)
"Stop: 0x000000A5" error message typically indicates that the computer BIOS is incompatible with the Advanced Configuration and Power Interface (ACPI) standard that is supported in Windows 7. However, this error can also occur because the computer hardware, the peripherals, or the drivers for those devices are incompatible with Windows 7.
Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Refer the following link for more information:
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7
Jan 11, 2011 | E-Machines eMachines Desktop PC
Nuendo 3 not working in windows 7
Jan 29, 2010 | Steinberg Nuendo 3 for PC
Steinberg Nuendo 3 for PC Logo
738 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
