Question about Yamaha RX-V361 Home Theater Receiver
How to connect Satellite to av 2600
Hi:
I am trying to connect my satellite cable to av 2600. Does it have coaxial cable input?
If not, is it possible to convert coaxial cable to s-video?
you can reach me at 908-720-8360 or, email at raghu101@gmail.com
thanks
Raghu
  • Raghu101 May 12, 2008
    Thanks,
    but the satellite dish has only the coax cable and I wanted to hook that to my Yamaha RX av 2600,
    what are my choices, is there any tool that take the coax as input and an S video that gets the output from the box to AV?
    How about if I say connect to my VCR and then output from VCR to my AV using S video, will it work?
    thanks in advance for your help,
    Raghu Nathan
  • 979 Answers
No conversion from coax to S-video as they are 2 totally different signals. Use "Line" from one to the other....accordianman
Posted on May 10, 2008
  • Michael Borelli May 12, 2008
    You may certainly use the VCR as the "converter" device to achieve your goals, by all means. The only loss you may have is a lack of a stereo signal from this setup as some converter boxes do not process stereo. You'll have to look up the specs for that particular box...accordianman
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
How do I eliminate the humming on my Vizio VHT-510 system
see this instruction and fix it. God bless you
    • 1
      Disconnect the coaxial cable at the back of the satellite receiver or cable box by unscrewing the coupler on the cable end.
    • 2
      Attach the cable to the RF IN jack on a surge protector and tighten the coupler clockwise.
    • Sponsored Links
    • 3
      Connect a second coaxial cable from the RF OUT jack on the surge protector to the input on the cable box or satellite receiver. If this stops the hum, congratulations: You're done.
    • 4
      Unplug the subwoofer's electrical cord from the power strip or wall outlet if it is connected to the same circuit as the AV receiver. The amp in the AV receiver and the amp in the subwoofer are in conflict over the grounding of the electrical circuit.
    • 5
      Plug the subwoofer into its own surge protector and connect the surge protector to a different wall outlet than the AV receiver uses.
    • 6
      Disconnect the subwoofer cable from the back of the sub and the AV receiver if all other measures fail to stop the humming. Reverse the plug connections so the plug that had been connected to the receiver is now connected to the subwoofer. Turning the cable around may solve a problem known as ground-loop hum by reversing the shielding wire inside the cable.
Read more: http://www.ehow.com/how_6979184_eliminate-sound-home-theater-subwoofer.html#ixzz2ZdzrgBSa
Jul 20, 2013 | Vizio Vht210 2.1 Home Theater Soundbar...
How do we connect our system using a Shaw PVR
Do you have a optical/coaxial input on your system? Eg: cable, TV.I use a optical input on my Yamaha ( cable, satellite ). Look to see if there is a optical/coaxial output on your pvr, there should be. Use ether the optical or coaxial output from your pvr and connect it to the cable (satellite ) optical/coaxial input on your receiver. The manual that came with your Shaw PVR should explain how. You will get 5.1 surround if available on certain channels.I prefer optical over coaxial myself, but they both work well.If you don't have optical/coaxial inputs on your receiver, you will have to use RCA cables, analogue out on cable box, to tape input or aux on your receiver. You will not get surround sound, just stereo. But it's better than nothing.
Jan 18, 2013 | Onkyo Ht-rc330 5.1-channel Home Theater...
I have a 42 in LG HDTV and a dish satellite and a LG surround sound system how to I hook these up to hear sound while watching the sat
See if your satellite receiver has a digital out socket in the back ( optic / coaxial ). If so get yourself an optic/coaxial cable and link the TV out to your LG Home Theaters optic/coaxial In.
Now if your Satellite receiver does not have a digital out for sound you will have to connect the TV's audio out to the LG Home Theater Systems Aux / SAT / CBL input using appropriate cables .Either 3.5mm phono to 2RCA or 2 RCA to 2 RCA cables.
Mar 12, 2011 | Audio Players & Recorders
Audio display flashes in and out in the upper right corner
This usually happens when you are connecting a cable box or satellite tv box to the television with a coaxial cable. In order to get this to stop you have to connect the cable box or satellite tv box to the television with an RCA/composite cable. Then you will have to change inputs to the appropriate one with the input button on the television (press it repeatedly) or with the input button on the Sharp remote (press is and then scroll down with the down arrow and press enter).
If you are not using a cable box or satellite tv receiver you can try connecting a signal booster to your coaxial cable but that is not guaranteed to work.
Jul 13, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Sounds is lower than it should be, possible short.
Having read the problem report two or three times, it appears that you're running ~three~ cables from your cable receiver to the home theater system - orange, and red&white.
Often, when you can hear a low-level signal on an input, it's due to 'leakage' from another input, and it's my hunch that the cable receiver is sending audio through the red and white (analogue) connections, which you've plugged to the main sat/cable receiver inputs.
To confirm this, I'd be interested to know if, when you unplug the red and white connectors from the back of the Onkyo, the quiet signal completely disappears.
If that's the case, I would suggest either going into the cable receiver's cofiguration to see if 'digital audio out' is set (if such is possible) or switching the input to 'cable/satellite'...
Hope this brings you closer to the root of the problem!
Feb 07, 2009 | Onkyo HT-S5100 Theater System
Dish network box hookup question.
Are you sure that the antenna in isn't threaded? You may be looking at the wrong jack... All antenna inputs are threaded co-axial "F" connectors. If you ARE sure, could you post a pic of the back panel?
Sep 12, 2007 | iLO 2600 Television
Connecting coaxial cable to dvd-v9700
I was thinking of using the RF modulator box, but in this case, it might not work, since signal should be coming from the cable box. What I dont know if there is a converter for signal from a coaxial cable to an RCA. However, the only way to connect is via RCA.
Sep 06, 2007 | Samsung DVD-V9700
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Yamaha RX-V361 Home Theater Receiver Logo
75 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
