Question about Dell Inspiron E1505 Notebook
No ethernet drive ? where to find it - Dell Inspiron E1505 Notebook
  • Dell Master
  • 4,737 Answers
The driver for your Ethernet Controller is available on the Dell Official Website.
First of all, download and install this (click here) [open the link and click download, you'll be presented with another windows to select the the download mode, select "Download Via Internet Browser" (if you can download using the dell download manager, go ahead, but if you are not sure, just opt for Internet Browser otherwise you may have problem with it.)] and download will begin automatically. Install the program (it's also possible that you can only extract at the first installation process, in that case you'll need to reinstall it from the directory/folder where the extract is saved [note the location before you start extracting]) After you are done with the first installation, now install the Ethernet driver (click here to download windows xp driver). Since you didn't mention the Operating System, I can't make it specific, but if the operating system installed on your laptop is windows vista, (click here). [follow the same procedure to download and install as mentioned in the first install.]
If you need further help, let me know with more details about your system and the operating system installed on it.
Good luck.
Thanks for using FixYa.
Posted on Sep 02, 2010
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I formatted the hard drive connecting it directly to the computer (using Windows XP). Then when i reassemble the Ethernet Big Disk, it turned on but it doesn't do anything. My question is: Is the...
the OS of the Ethernet Big disk is on the hard drives, so you did erase them. This unit should only be formatted using the administration page drive format option.
LaCie usually does not give away the OS, so your option would be to close some other Ethernet Big Disk or Ethernet Disk Mini drives unto your now formatted drives.
Regards,
Jan 05, 2011 | LaCie (300966U) 1024 GB Hard Drive
Network is running out of space.
scary option
move all data off the d drive to x
then change d drive letter to Y:
then when d letter is free change the drive x to D
its dirty but it will work. might need restart but not sure .
if you have loads of data then its more difficult
Mar 01, 2010 | LaCie Ethernet Disk (301298U) 2000 GB...
Ethernet/lan missing so i can not connect to the internet
Download and install the driver from the manufacturers website. Use an external hard drive or flash drive to download from internet (working computer) and install from there.
Oct 03, 2009 | Foxconn 915P7AC-8KS Motherboard
Can I upgrade a dell inspiron 6000 to gigabit ethernet?
There are USB 2.0 gigabit ethernet adapters:
Here
However, I am not so sure if you would bottleneck from the USB connection or not.
Hope this helps,
Bill
Sep 06, 2009 | Dell Insprion/Latitude C, XP Series...
Fan keeps going, blue light always on, clicking noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Jun 28, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Ethernet cable
Its just optional if you like to use a Ethernet cable for this device , for us long the device is connected via USB its definitely fine....
Dec 15, 2008 | Western Digital 500GB My Book World...
Unable to locate Lacie Ethernet Disk Mini on the network
Lacie's out to lunch..you may be experiencing the old drivers are shot issues..get em from the main site, and reinstall, ok?
Mar 24, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Dell Inspiron E1505 Notebook Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
