Question about JVC RX-317 Receiver
I have a j.v.c rx 317 model reciever i've noticed that i get nothing on the display only the red light indicator light comes on and not the display lights, can you please help me
3 Suggested Answers
SOURCE: JVC RX-ES1SL 5.I
1: In most cases there are two FET`s gone you can use a normal IRF 530 but cut the heat sink from the FET do it with a pincer not with a grinding machine! (static electricity!). Before you switch on the set pay attention for the following parts!
2: The two coils that are mounted under the metal housing on the main board look of they have a other color if so they are burnt Check also the SMD parts under the main PCB.
3: The two SMD Elco`s that are mounted on the little PCB they have in most cases a high ESR. The value must be under 1 I thing that all the troubles you can have with this set are coming from this two elco`s (100uF 16 volt.)
4: look for a short cut on this little PCB pay attention to the two SMD gates. Measure the S/C over the +5 and +12 volt lines and check both PCB visual.
5: You must bring in a lot of heat to remove the both IRF`s use a good flux and do not fear the heat they can have it.
Because you must use a big Iron there is the danger to damage this aluminum layer check visual after you have solder the two FET`s all the connection with the smaller parts measure them with a Ohm meter. This was the fault in mine case there was a open connection to one of the gates of the FET`s
Posted on Jun 03, 2008
SOURCE: home theater reciever
Check the internal fuses havn't burnt out. Remove the main cover. There are 4 glass fuses.
Posted on Jul 07, 2008
Red light comes on but power button won't turn it on
Please confirm actual brand and model as it is not clear what set you have
Mar 11, 2012 | Televison & Video
Yamaha rx-365 reciever not showing all speakers
I,m not familiar with the Yamaha but most receivers are set up the same way. In your setup menu are the speakers marked on in the display?. Your DVR needs to be transmitting in 5.1 to start with. If this is the case then make sure you select the correct audio function on the receiver.
Mar 04, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
3 light on last two blink
The first light, I assume is on constantly, is power/connection, and the two that blink will be Rx and Tx, Rx = recieving data sream, Tx = sending data stream, even if you think that nothing is being transmitted, "static" is sent/recieved to maintain your connection.
Jun 11, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
The display light doesn't come on to indicate what the unit is doing (frequency, mode, etc.)
I assume that it plays, you just can't see the display. It may just need a new display bulb, that back lights the display.
Feb 22, 2009 | Yamaha RX-V730 Receiver
I just purchased a yahama rx- v850 av reciever
if you dont mind a lettle customization, just go to radioshack and set your favorite color l.e.d. and wire it in, if you can find a specs diagram for your reciever, you might look up voltage and wattage of the bulb so you can get appropriate resistors for the led, and install that. itll last forever, cost virtually nothing, and its easy to do.
Jan 11, 2009 | Yamaha RX-V461 AV Receiver
Jvc rx-dv31 standby light comes on, but wont turn on, just clicks then turns off
sorry but this is an electronic malfuction or failure , it will need repair
leave it unplugged to prevent further dammage untill you can take it to your local electronic repair shop
electech
Oct 27, 2008 | JVC RX-DV31 DVD Player
Home theater reciever
Jan 20, 2008 | JVC RX-ES1SL Receiver
103 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
