System will.not post
Hi all
My P5PE-5VM will not post system is on power light on
new memory board new post one time and that was it
all fans working new power suppy work test in differt system
reset bois reset system. remove memory here system error
put memory back in no post
  • rhynovan Jan 19, 2009
    Power light, CPU and chasis fans all come on. Hard disk powers up. But there is nothing on the screen, nor any post beeps from the chasis speaker.
    Have tried removing all the expansion cards, unplugging the hard drive and DVD ROM from power and SATA ports, and even swapping the memory modules without any change.
  • Mark Kessler May 11, 2010
    What shows up on the screen when you turn on the computer?
    Are there any error messages or a series of beeps?
Can anyone help me pls. fix my problem. My P5PE-VM Asus Motherboard having a problem error loading operating system. I replace my RAM, power supply and hard disk drive but seem's the error is not fix....I'm out of idea can anyone knows it and solve the problem.. I appreciate to thanks in advace!!!..
Posted on May 10, 2008
My Dell optiplex 790 desktop compuer doesnt boot, no beeps and key board isnt working.the power fan works and no light the mother board is on,what should i have to make my comp fixed?
Not sure about dell mobos.. Asus usually has some led indicating there is current running on the board even if it's off..
From my experience i can say if there is no beep that means the memory is defective, preventing the system to do P.O.S.T. (power on self test) which is where the beep comes from.
Being a Dell system i'd say you should go for it's help desk.
If that's not a option you can remove the memory and see if there is a beep, if not, the other part that can prevent the system to POST is the processor.. If you have another (working) system you should test both memory and processor there.
Dec 05, 2013 | Computers & Internet
Hi. I have an old Asus P5PE-VM motherboard which won't switch on
here is a pic look at the right top right side there is a 4 pin power plug and make sure that you have the cpu fan wires to the cpu plugin it says cpufan on board ok http://www.asus.com/Motherboards/P5PEVM/
Jan 06, 2013 | ASUS P5PE-VM Motherboard
How much video card memory does the p5pe-vm board supports? cause i have installed the geforce 6600 256 mb , and it only detects 128mb.. and when i run dxdiag , it says there ( approximate memory: 1
Eyaa! Use www.systemrequirementslab.com ant take one random game to check your computer performance, there it will show your computer performances.
Mar 14, 2012 | ASUS P5PE-VM Motherboard
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
Won't boot up
First of all make the memory is seated properly and that the motherboard supports the clock speed of it, i.e 400-800 MHz.
Then make sure that the processor is seated properly, take the processor out and put it back in.
Next if you are using a AGP graphics card and not any on-board graphics make sure the card is seated properly in the slot. A good idea to test the system is to use the on-board graphics port first.
Also clear the CMOS with the jumper that should next to the motherboard battery. If there is no jumper there remove the lead from the back of the unit and then take the motherboard battery out for around 20 minutes periodically hittting the on/off button to drain any residual power from the motherboard.
After 20 minutes are up put the battery back in and power the machine up.
Good luck and please post back if you need anymore help.
Regards.
May 27, 2010 | ASUS P5PE-VM Motherboard
Nx9010 powers on but no video. fan spins.
Hello sir, hi, it seems you have a problem with memory modules, you need to open up your PC/laptop, and locate the memory. remove the modules, and clean its terminals (you clean then using a pencil eraser, just simply erase the terminals, until the contacts become shiny), with a soft clean paint brush, clean the memory slots too, then replace the modules, close then test the unit. do this several times until the unit boots up. keep me posted.
Mar 25, 2010 | HP Compaq Presario 2500 HP Pavilion ZE...
How to detect p5pe-vm mother board defective i have issue when i power on the p5pe-vm pc no dispaly noting ,no beep sound mother board getting power processor fan is running so how ICAN SOLVE THIS ISSUE...
Hi , Has your MB Sufferd any power Surges , Power Trips , or Shorting with Case of some sort? if so then your Motherboard is Burnt out , Try see if you can see any burnt marks , or Burst Capacitors .As soon as your CPU Fan runs , but your MB isnt running , you know its getting power ..So your motherboard is Burnt out, ASUS boards are very commonly , Burning out.I recently Sent mine back to ASUS because it burnt out..Also if you are going to take it in , make sure you have a proper qaulified Techie Checking it , otherwise they report that your CPU and PSU is also burnt out , and try get you to buy new from them...Becareful of that , its very common where im from.
Hope this Helps
Thanks
Dec 31, 2009 | ASUS P5PE-VM Motherboard
My d530 minitower powers off unexpectedly and red lights starts to blink on System's LED//
Hi Kindly let me know how many times the red light blinks
Condition Code Service Actions Processor thermal protection activated. Power LED blinks red twice, once a second, followed by a two second pause.
  1. Make sure the computer air vents are not blocked and that the cooling fan is running.
  2. Open the hood, press the power button, and see if the processor fan spins. If the fan is not spinning, make sure the fan cable is plugged into the cable header on the system board, and that the fan is properly installed and seated.
  3. If the fan is plugged in and seated properly, but is still not spinning, replace the processor fan.
  4. Reseat the processor heatsink and make sure the fan assembly is attached to the heatsink properly.
Processor is not installed. Power LED blinks red three times, once a second, followed by a two second pause.
NOTE: This condition indicates a missing or improperly installed processor, not a defective one.
Make sure there is a processor in the system. Reseat the processor and verify that it is installed properly. Power failure (power supply is overloaded) Power LED blinks red four times, once a second, followed by a two second pause.
  1. Check the voltage selector, located on the rear of the power supply, is set to the correct voltage (the correct setting depends on the region).
  2. Open the hood and make sure the 4-wire power supply cable is fully connected to the power connector on the system board.
  3. Check if a device is causing the problem by removing all attached devices (such as disk drives and expansion cards), then power on the system. If the system enters POST, power off and replace one device at a time, repeating the procedure until the system power failure reoccurs. Replace the device that caused the failure, then replace each of the other devices and confirm that they are functioning properly.
  4. If you cannot isolate the failure to a specific device in the previous step, replace the power supply. **
  5. Replace the system board.*
Pre-video memory error. Power LED blinks red five times, once a second, followed by a two second pause, and five simultaneous beeps are sounded
  1. Reseat the DIMMs in the memory slots on the system board, then power on the system.
  2. Replace the DIMMs one at a time to isolate the faulty module.
  3. Replace 3rd-party memory with HP memory.
  4. Replace the system board.*
Pre-video graphics error. Power LED blinks red six times, once every second, followed by a two second pause, and six simultaneous beeps are sounded. For systems with a graphic card:
  1. Reseat the graphics card and then power on the system.
  2. Replace the graphics card.
  3. Replace the system board.*
For systems with integrated (on-board) graphics, replace the system board. PCA (system board) failure. ROM detected failure prior to video. Power LED blinks red seven times, once a second, followed by a two second pause, and seven simultaneous beeps are sounded. Replace the system board. Invalid ROM based on bad checksum Power LED blinks red eight times, once a second, followed by a two second pause, and eight simultaneous beeps are sounded.
  1. Reflash the ROM using a ROMPaq diskette.
  2. Replace the system board.*
System does not power on. No beeps or blinks since the system is not functioning. Press and hold the power button for less than four seconds. Perform the following steps depending on whether the hard drive LED turns green.
If the hard drive LED turns green, then:
  1. Make sure the voltage selector (which is located on the back of the power supply) is set to the correct voltage for your region.
  2. Remove the expansion cards one at a time until the 3.3V auxiliary light on the system board turns on. If removing a card turns the light on, replace the card and then see if the system works.
If the hard drive LED does not turn green, then:
  1. Make sure the computer is plugged into a functioning AC power outlet.
  2. Open the hood and make sure the power button is securely fastened in the power harness and that the harness is connected properly to the power connector on the system board. In other words, make sure that the power button is making contact with the power circuit.
  3. Make sure the power supply cables are connected properly to the power connectors on the system board.
  4. Check to see if the 3.3V auxiliary light on the system board is not turned on, replace the power supply. **
Dec 29, 2009 | HP Compaq d530 Convertible Minitower PC...
Graphics card problem
Hi rovin,
So you bought an XFX GeForce 256MB video card. You're board has 1 free AGP 8x video slot & 3 PCI (White opened slots).
You mention there is not slot for the new card. (What type of video card did you buy)? PCI-E, AGP or PCI?
The only slot you're board does not have is a PCI-Express.
Look in you're manual on page 1-7 for the location of the AGP video card slot.
94565e6.jpg If you bought the wrong card, exchange it for an AGP 8x or PCI.
The ASUS P5PE-VM uses a integrated Intel® 865G chipset with integrated Intel® Extreme Graphics 2 Technology, which uses you're system memory to function.
If you need a manual you can download it from Asus. Click on the link to open to the P5PE-VM download site.
http://support.asus.com/download/download.aspx?modelname=P5PE-VM&SLanguage=en-us
I hope you find this helpful.
Mike
May 11, 2008 | ASUS P5PE-VM Motherboard
There is a problem in starting the system
check the battery and check the hdd belt also and also check the smps
Jan 17, 2008 | ASUS P5PE-VM Motherboard
Computers & Internet Logo
546 people viewed this question
David Payne
David Payne
