Question about The Learning Company Super Solvers - Gizmos & Gadgets! (798936820037) for PC, Mac
Want to run gizmos and gadgets on windows 7 PC
¡Muchas gracias! Usted es realmente ?til! Los individuos tambi?n pueden visitar https://plus.google.com/108575569080700033613/posts/4D5pxfTcdu9 para obtener las claves de Windows Original y barato para activar sus ventanas.
Posted on Jun 07, 2016
3 Suggested Answers
  • 53 Answers
SOURCE: The Problems with The Learning Company Super
this game will not run on vista or win7 without an emulator beacause it is 16 bit software. I recommend trying dosbox.
Posted on Oct 29, 2009
SOURCE: want to run Gizmos and Gadgets on Vista PC
I got Gizmos and Gadgets to work on my Vista PC by copying the entire CD to C:/Windows/System32.
After that, open the "ssgwincd" folder, and inside that folder open "ssgwincd" again. Inside the second folder there will be a file called "ssgwincd.exe" right click on it and select properties. In the properties window click on the compatability tab and set the program to run in compatability mode for windows 95 and to run in 256 colors and in the 640x480 window
It should then work for you, but I would suggest putting a shortcut to the program on your desktop so you can find it easier later on.
Good Luck!
Posted on Feb 28, 2009
When I download windows gadgets in a folder on my Windows 7 desktop and then click to open a gadget file windows does not recongnize it and asks me to associate a program that will open the file. How shall...
On your desktop simply right click and select gadgets from the menu. Now drag your downloaded gadget file(not folder,just the gadget) into an empty slot in the gadget window. Now you can add this gadget to your desktop.
Aug 22, 2011 | Microsoft Windows 7 Home Premium, 32-Bit,...
I'm try to install new window 7 64 bit into compaq presario c700 ,but load and stand after window load. it says window starting and nothing happen.
Hi there !
If there is problem on loading you window 7. Try to run it on safe mode by pressing F8 when starting to reboot your computer. When running on safe mode, windows will automatically fix some error regarding some loading problems.
After press F8, just choose run on safe mode and it will read and fixed all errors on drivers. Computer can crashed because of faulty drivers installed or too many same drivers installed. This solution will fix your problem.
I hope it helps you. Thank you for using FixYa !
Jan 09, 2011 | Computers & Internet
How I install new gadgets for my computer
Go to
http://windows.microsoft.com/en-IN/windows/downloads/personalize
download and install the gadgets you like from all the Microsoft galleries.
Nov 09, 2010 | Microsoft Windows 7 Ultimate for PC
Windows 7 gadgets working wrong
You dont need side bar anymore, rightclick anywhere on desktop and goto gadgets, Add the ones you want, put them where you want (side, top, anywhere) and thats your gadgets as they were in vista.
If you have installed Windows 7 beta then you must be aware of the bug that whenever UAC is switched off, Sidebar and Gadgets in Vista fails to display properly on Windows 7 Desktop. Though this is not for every machine but many users have reported this problem that their Sidebar and Gadgets are not working properly.
For older beta versions of Windows 7 there had been some temporary workarounds for the same problem. But if you are using Win7 Build 7000.0.081212 then this can be fixed using a simple registry hack which like in Vista will Elevate your Sidebar and Gadgets Process.
If you know how to play with you registry Editor then just open regedit.exe from Run command in Windows 7 and go to KEY
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
\CurrentVersion\Sidebar\Settings From there edit the DWORD value of AllowElevatedProcess and set it to 1. You don’t need to restart your Windows 7 computer after this. If your sidebar and Gadgets were not working properly earlier then they will be fixed instantly.
Jun 19, 2010 | Microsoft Windows Vista Home Premium with...
IT WONT WORK ON VISTA IT SAYS SOMETHING ABOUT THE MIDI DRIVER FOR THE SOUND CARD IS NOT FOUND IS THERE A WAY TO GET IT TO WORK WITHOUT GETTIN A NEW SOUND CARD
if the computer prompts you to install a new sound card, it means you cannot run the program without the sound card. you need it inorder for the progam to be compatiable with your pc desktop/laptop.
Feb 25, 2010 | The Learning Company Super Solvers -...
Clock gadget on windows 7 deleted by error.
In the Control Panel, Appearance and Personalization. Try the Restore desktop gadgets installed with Windows or Add a gadget. I'm not sure if the restore will work; adding a new clock gadget, at worst, would make the computer think you have two loaded (with the clock that is sometimes desirable to check the time in multiple time zones).
I hope this helps.
(I assume you merely misfiled your request since it said WinXP above.)
Jan 16, 2010 | Microsoft Windows XP Professional With...
We have a second hand one of these with a password still in progress. how do I rest the password
BIOS passwords on these things can be removed with one of 'em parallel port password removal device/gadgets. Or you can make your own - the schematics is available on the internet.
Once you have the gadget, or gizmo, plug it into the parallel port, turn the machine on, and the BIOS password will be gone.
Dec 12, 2009 | Toshiba Satellite 1800-S253 Notebook
Game won't run
HI ^^
http://www.touslesdrivers.com/index.php?v_page=29
clic on lancer la detection
follow the instructions
the website will show all missed drivers found so you can download them directly from the website
HOPE IT WILL HELP YOU
RATE IT ^^
Jun 02, 2009 | The Learning Company Super Solvers -...
Want to run Gizmos and Gadgets on Vista PC
Good Luck!
Jan 26, 2009 | The Learning Company Super Solvers -...
The Learning Company Super Solvers - Gizmos & Gadgets! (798936820037) for PC, Mac Logo
3,173 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Stitch85
Level 1 Expert
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
