Question about Nokia 6111 Cellular Phone
No sound My phone will not make any sounds, its set to general and not vibrate but will still not ring, I have tried to play ringtones but still nothing, any ideas?
  • wranco May 27, 2008
    The phone is not ringing.I even changed the ringer but still its not ringing.
  • 33 Answers
Explore the GENERAL mode, set the level to what you want, choose a tone, dnt choose NO RING/NO SOUND or other words. or the problem is on incoming call alert, then choose RINGING. hope this can help. :)
Posted on May 17, 2008
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    How do you adjust the volume on the Samsung T255 StraightTalk phone?
    Sound Settings
    You can customize various sound settings.
    Incoming call
    Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
    Ringtone.
    This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
    Volume
    This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
    • Use the Right or Left key to increase or decrease the volume.
    Alert type
    This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
    The following options are available:
    - Melody: the phone rings using the ring melody selected in the Ringtone menu.
    - Vibration: the phone vibrates but does not ring.
    - Melody and vibration: the phone rings and vibrates simultaneously.
    - Vibration then melody: the phone vibrates three times and then starts ringing.
    - Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
    Message tone
    This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
    • Use the Up or Down Navigation keys to make your selections.
    Keypad tone
    This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
    phone sounds when you press a key.
    Jan 25, 2011 | Samsung T239 Cell Phone
    My phone will not ring out loud and vibrate at the same time.
    To turn on a ringtone and vibration, go to your BlackBerry's sounds and ring tone options by either of the following ways:
    1. Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
    2. In the Home folder, go to your Options folder (usually toward the bottom, has a wrench icon) and select Sounds and Ring Tones.
    Select the ring tone and volume that you want, and for Play Sound select Always. Scroll down to Vibration and set it for On.
    There is an option for Vibrate with Ring Tone -- set that to on in order to make your phone both ring and vibrate at the same time, then save the settings when you cancel out, and you're all set.
    Jun 21, 2010 | RIM BlackBerry? Tour 9630 Smartphone
    How to get sound as well as vibration on my cell phone
    depending on your cell go to menu/option tools/settings /alerts/ringtones/ here is where you can give that special ring tone to a caller...general rings for everyone...vibrate/ring for family...its your call....
    Jun 29, 2010 | Cell Phones
    How do I turn off the key pad tone on the impression sgh-a877
    The Sound Profile only covers call sounds.
    Sound Profiles
    This menu allows you to specify how you are informed of
    incoming calls.
    Selecting a Profile
    1. Touch ➔ Settings ➔ Sound Profile.
    2. Touch the radio button next to the profile name. The
    selected profile activates. Choices include:
    • Normal
    • Silent
    • Driving
    • Outdoor
    Normal Profile
    The phone’s profile defaults to Normal. Use the following
    procedures to change the profile.
    Editing the Normal - Call Profile
    1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
    • Touch the name field and not the radio button to the right.
    2. Touch drop-down menu (upper-right of the screen) and
    select Call.
    3. Select the Call Alert Type field and select one of the
    following and touch Save:
    • Melody: the phone rings using the ring melody selected in the Ring
    tone menu.
    • Vibration then Melody: the phone vibrates and then starts ringing.
    • Vibration & Melody: the phone vibrates and plays a melody
    simultaneously.
    4. Touch the Voice Call Ringtone field, touch to select a
    ringtone and touch Save.
    5. Drag the Ringtone Volume slider to the volume level you
    desire (range is 1-7).
    6. Touch the Vibration Pattern field, then touch to select
    Vibration 1 - 5.
    7. Touch Save to return to the Sound Profiles menu.
    There is no mention of keyboard tones in the user manual.
    Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
    Motorola Adventure 750 phone-- no speaker sound. Why?
    You've probably already tried these, but what the heck; you asked...
    1) Check in MENU -> SETTINGS & TOOLS -> SOUND SETTINGS -> CALL SOUNDS -> CALL RINGTONE to make sure that you have actually selected a ringtone instead of the "No Ring" option at the bottom.
    2) With the phone open, try the up/down buttons on the left-hand side of the phone (above the Push-To-Talk button) to make sure that your volume isn't set to "All Sounds Off," "Alarm Only," or "Vibrate Only." It has to be at least at "Low" before a ringtone will play.
    Hope this helps. If not, you probably need to take it in to a Verizon store for an expert assessment; they'll usually take a look at your phone and install any software updates for free.
    Mar 10, 2009 | Motorola Mobility V750 Cellular Phone
    No ring, only vibrate
    if the ringtones ring from settings or the songs play then it will be surely the settings problem please select ring and vibrate instead of vibrate only and if it doesn't works then go to a near by repair shop and ask them to check and change the buzzer
    May 02, 2008 | Nokia 6288 Cellular Phone
    No sound when phone rings
    I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
    Jul 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
    Will not ring or vibrate.
    Go to settings... personalize....ring type... pick loud ...scroll down to edit then go in and change from silent to the ringer setting you choose
    Jun 26, 2007 | Motorola Mobility PEBL U6 Cellular Phone
    Nokia 6111 Cellular Phone Logo
    94 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
