Question about Lasko 3135 Stand (Pedestal) Fan
Need parts to make it oscillate - Lasko 3135 Stand (Pedestal) Fan
  • 490 Answers
Howdy, Lasco could not locate a product 3135 (there may be an error in the numbers on the message) but here is the contact info for them. http://www.shoplasko.com/customer_care.asp. If we can help with anything else, we are always here. Thanks for using fixYa.
Regards,
Farmerbear
Posted on Sep 02, 2010
Why won't my fan oscillate?
There is a little arm attached to the motor that makes the fas oscillate. If it gets disconnected you will have that issue. Check the linkage.
Feb 29, 2016 | Dyson AM05 Hot Cool Fan Heater
Why wont my dyson fan oscillate?
Hi there, it's Jack at Dyson.
Your Dyson Air Multiplier AM01 desk fan should oscillate when you press the oscillation button on the base:
If you find that it's not oscillating when this is pressed, we'd need you to contact our Support team directly - we can confirm if we're able to resolve this for you under our free 2-year parts and labour guarantee.
You can reach us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 08, 2014 | Dyson Air Multiplier 10" AM01 Bladeless...
We need a wall mount bracket for the Lakewood RR/16WM Oscillating Wall Mount Fan
I'd suggest you contact the manufacturer and see if you can order that one part.
Jun 23, 2014 | Lakewood RR/16WM Oscillating Wall Mount...
Heat does not come out of defroster
An oscillator? :vibration, motion like a pendulum, pulsation, fluctuation, rotation...yeah, I can imagine Nissan calling a door that swings back and forth to direct air, an oscillator. Hope someone is not pulling your leg, though, or we've both been suckered ! Don't know what to tell you, except to find your nearest oscillator outlet supplier. In the meantime, check the controls to the various doors on the heater case. Are they vacuum controlled, cable controls, or electrical motor controlled? Usually all of one type. You may be able to see the offending part, a disconnected hose or cable, or the stem of an inner door that has broken or not moving the door. The oscillator might be hidden deep in the bowels there-be careful. Good luck, norman.
Feb 25, 2013 | 2001 Nissan Quest
Remington Hedge Wizard - driver/oscillator assembly broken - motor turns blades do not oscuillate
Hello There, blades oscillating are usually controlled by the motor. When the motor is rolling then the fan not oscillating is usually a minor problem. Usually the blades are connected to the motor using a rod which is directly connected to the blades.
If the oscillator assembly is faulty this could need replacement of a part. And this would require expert help. Which part exactly is broken? How well can you handle mechanical assembly parts? i could try to get you an assembly guide to help determine which part is faulty exactly but i need to know the above.
Hoping to hear from you soonest.
Thank you for visiting FixYa.
Aug 01, 2011 | Remington Garden
My ryobi oss450 has stoped oscillating. Is there anything I can do to repair it? It operates just fine except for the oscillating.
You can try taking it apart and cleaning the mechanism that makes it oscillate, but i have found most times when those stop they are just wore out and need replaced. Those sanders are pretty much disposable.
Mar 17, 2010 | Tools & Hardware - Others
Aloha Breeze Tower Fan Will Not Oscillate
hi,
yes this is the oscillation motor, and they generally arent servicable, and need to be replaced, you can try and oil it, sometimes they have small air vents, and you can do a voltage test with a voltmeter but I believe the motor has failed or is gummed up, you can try and take it apart, they are held together with bent metal compression areas along the circumfrence of the motor, try sewing machine oil, you might have to do some research to find a replacement motor, maybe take it to a local clock shop, those motors are very close to what they used to put in old wall clocks.
good luck
J
Aug 05, 2008 | Tower Aloha Breeze Fan
Internal Part's Guide for Model A0J-1201 fan
there will be a oscillation driving counter wheel present inside it which is made of plastic tat would have got damaged or broken so replace the wheel then ur fan will start oscillating
Jul 28, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Lasko 3135 Stand (Pedestal) Fan Logo
138 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
