Question about Sony Ericsson K800i Cellular Phone
Camera shutter I know this isn't really a terribly horrific thing but the camera cover keeps opening in my pocket, any ideas how to keep it still! cheers curly
  • Josh B
    Josh B May 13, 2008
    thanks, any one know how to take it off??
Use an elastic band
Posted on May 12, 2008
How to disassemble lens on a casio exilim ex-z75
Jim, I really wouldn't recommend this. It requires extreme patience and meticulous parts tracking. Note that junctions stated: "It's really hard to take apart,", and he ain't kidding.
Really recommend that you return to the remedies that you had been trying. Sometimes it requires many repeated tries to free the gunk from the shutter. I've found that for the smaller pocket cameras that the most effective solution seems to be extending the lens and tapping around the lens barrel with a pen/pencil. Then alternately opening the battery door with the camera turned on (no need to play with shutter modes). Then just alternate with tapping, battery door, tapping, battery door, and keep doing this until the shutter opens/closes. Once this happens, set the camera to continuous shutter mode and snap off about 100 pictures to final lubricate the shutter.Good Luck,t00nz aka CR
Nov 22, 2011 | Casio Exilim EX-Z750 Digital Camera
Tip
DIGITAL CAMERA MAINTENANCE
charge battery after every use
always remove battery when not in use
be smooth while inserting and removing usb cables
keep clean the camera case (leather cover / cloth cover)
never keep digital camera in your pant pocket (back pocket)
gently clean barrel unit (lens assy) before switch off digital camera
on Feb 06, 2010 | Cameras
Old Program A camera -mirror jammed in open position and shutter will; not open when the shutter release butten is pressed
From what you've given, it sounds like the shutter is fried, or the mechanism jammed - or both. If you're wanting to keep the camera, and use it, you'll need to contact a repair technician and have them take a look at it for a repair estimate - assuming it's able to be repaired. Estimates will run you around $35 most places, if there's no shop near you KEH Camera which has a website is quite good.
The same thing just happened to my Nikon FE, and my estimates have been ranging anywhere from $105-145 to get it fixed, so the decision of whether to repair or replace if really left up to you.
Aug 29, 2011 | Pentax Program A 35mm Film Camera
Hello guys, I'm an amateur just got a cannon oed 550d and I'm having some problems. When I try to shoot the Aperture and Shutter speed (that keep's changing) blink a few times, the flash goes off a few...
It's hard to say if anything is really wrong with the camera. It sounds like you haven't gone through the manual and tried the features as they are explained.
Jan 19, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Shutter won;t open
Are you talking about the shutter, or do you really mean the automatic lens cover ? Take a look at this first to see if this is what you meant. Make sure you read the comments also for additional tips. I don't think it will be necessary to open it up to fix it. Stick with the easy tips, they should work, especially if this is happening occassionally:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 05, 2009 | Canon PowerShot A570 IS Digital Camera
Lens doesn't open fully
Sounds like something has contaminated the protective shutter.
any idea what?
If its something sticky like coke then its unlikely to cause further damage, but if its grit or sand I wouldn't keep trying to open it as it may scratch the lens.
I don't specificly know this camera but have have had experience on many like it.
Basically the shutter needs removing, usually this involves removing the trim surrounding the lens which is usually held on with double sided tape but can be very well held on and the surround easily damaged then the shutter is often clipped in or held in with a couple of tiny screws.
It can then be removed and washed with isopropyl alcohol.
If its not something you would want to attempt yourself a good camera shop that offers repairs should be able to help.
although if the lens is contaminated with sand or grit, eventually it may work its way into the gearbox and jam the lens..
best of luck
May 26, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens Cover Won't Open
NO Super glue this can be fixed pretty easily to get fixed. most local shops will not charge you to much to fix it maybe 15 to 20 at the most i figure. or you can remove the lens cover by putting a very small flat head screw driver on the side of the lens and with the camera off pull away from the camera and it should just pop off. Superglue if you get it on the lens will rune the whole thing. Just tiring to help out . I repair lens shutters all the time they are just mechanical parts nothing really special about them.
Apr 16, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Shutter will not close!
very small dust particals are the reason of this problem.I m suggesting an idea but apply it on your own risk.Keep camera in off position then slightly strick with ur fingernale around the lens ring evenly.This can make the lens shutter contrct.Once the shutter closed,clean gently with a painting brush over the edges where shutter slides from.do this for several times so that any hard dust partical causing may removed.do not insert anything inside.
Aug 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Lens
OK I know whats wrong with this one, because my cmaera did the same thing. The outside shutter in the lens opens, right? Well, the inside shutter is stuck. Its staying shut. Take the camera apart(or if you dont feel comfortable doing it yourself, take it to a expert)and tap the side gently, it should fix itslef like that. If not, its the same problme, but you'll have to take it in somewhere.
Jun 01, 2007 | Sony Cyber-Shot DSC-W7 Digital Camera
Digimax i6 pmp SHUTTER problems!!!
Congratulations on fixing the problem! However I just wanted to let you and everyone else who reads this solution know that the part which failed on your camera is not actually the shutter. The shutter is deep inside the lens assembly right next to the image sensor. What you were dealing with was simply a protective cover for the lens. David Millier Advance Camera Repair
Feb 03, 2007 | Samsung Digimax i6 PMP Digital Camera
Sony Ericsson K800i Cellular Phone Logo
43 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
