Question about Samsung LN-T4671F 46 in. LCD Television
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV would take considerably longer to start up (multiple clicks). But with patience (turning off and on again, sometimes many times), I would eventually see a perfect picture. This phase lasted several weeks, but progressively to more off-on attempts to achieve a perfect picture. Then, as of last week, even with patience, the best outcome was a good picture containing a few pixelated squares. Now things have completely gone bad: when cold, the TV usually displays vertical lines (multiple colors, more in pink tones); after a few attempts to restart, it will fail to even produce the rainbow lines (no picture at all, clicking sounds going on forever, or until I unplug it). Help with diagnosis please???
  • 70 Answers
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Posted on Sep 02, 2010
  • 1 more comment
  • rlane850 Sep 02, 2010
    Thanks for your insights. I'll get it checked out. Do these symptoms (pixelation developing into vertical rainbow lines) clearly point to the motherboard, or are there several parts in lcd displays that would be expected to give similar symptoms? I'll consider myself lucky if the repair turns out to be 200 bucks. :)
  • Ibrahim Yusuf
    Ibrahim Yusuf Sep 03, 2010
    The rainbow lines are probably a separate issue and most likely a problem on the motherboard, sometimes it could be a loose connection in one of the motherboard wires or it could be that the actual motherboard is going bad, either way, more than likely if you replace the motherboard it should fix both of your problems. But I would have the tech guy make sure that he does not charge you or put a new power supply when you dont need one, some techs will tell you its both and charge you for both with its only one or the other, sometimes it could be both but you need to show him you've done your research so you dont get overcharged.
  • Eric Jackson Jan 12, 2011
    Did this resolve the issue with the TV? Can you tell me if these parts are something I can get myself and replace? (I'm comfortable with soldering) Where would I get them?
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
I have a ln-s3238d that i got a couple years ago. Last month it started getting a line of pixels running across the top of the screen. over the last month that problem has gron to four lines on top and...
Hi andrew, its not a big problem.. Decent TV. but the pixels are DEAD. that means you have to recover them by fixing the LCD. this would cost you around £40-60 for a 32 inch TV. hope this helps!
Nov 05, 2010 | Samsung LN-S3238D 32 in. LCD HDTV
My Samsung 47 has a black film covering 1/2 the screen for about
Samsung only makes TVs that last 2 years, mine also has the same problem. Throw it away and buy a cheaper disposable TV, despite all the hype Samsung is just another cheap and nasty manufacturer who uses its customers as product testers. Why do you think they keep changing model numbers every week ?
Jan 13, 2010 | Televison & Video
Toshiba lcd series 6, 18 month old tv will not
consult manual for troubleshooting it could be that lamp in tv takes long time to cool down or that it is bad they usually last about 2-3 years depends on how you use your tv
Dec 31, 2009 | Toshiba Toahiba Satellite A70 A75 M35...
Picture rasterization
It sounds like the LCD controller board problem, usually if you cool it down the problem will go away, and comes back when it heats up again.
Nov 23, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Failed Samsung 40" TV
sorry to gave u a bad news bad the color card is the all panel , tell me the model # and i would check how musch is the parts
Mar 15, 2009 | Samsung HCL4715W 47" Rear Projection...
Red pixel cloud in plasma black
THIS IS THE START OF THE PLASMA GAS RUNNING OUT...PLASMA TVS ONLY LAST 4 TO 5 YEARS THE GAS JUST BURNS OUT....LCD TVS LAST ALOT LONGER UP TO 10 YEARS..
Dec 29, 2008 | Samsung PS42P2S 42 in. Plasma Television
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Keeps turning off
I am having the same problem, is there any solution for this problem?
Apr 11, 2008 | LG 47LC7DF 47 in. LCD HDTV
Samsung LN-T4671F 46 in. LCD Television Logo
768 people viewed this question
Jerry Greenberg
Jerry Greenberg
