Jmy fisher 717 blows the 5 amp fuse on the power board the instant i turn it on. what should the resistance be on the primary side of the power transformer? There is also a lot of discoloration on the power board around a transistor and two resisters.
4 Suggested Answers
  • 4 Answers
SOURCE: Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
Posted on Mar 07, 2008
  • 336 Answers
SOURCE: RCA 3870 Receiver problem..RE/RE
On the secondary of the transformer you would still have an ac voltage. The dc voltage will be after the bridge rectifier.
Posted on Jan 31, 2009
  • 6771 Answers
SOURCE: won't power up at all
If there is no power on on the primary side of the transformer look for a open fuse.
Posted on Apr 05, 2012
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Fisher & paykel washer no power going to it
No reset button. There is a fuse it is soldered on & part of the main control board. They don't blow the fuse for no reason, so you need to be able to test & check everything to find out why the fuse blew (if it has) If you just replace the control board without checking then there is a good chance it may blow the new board as well. There will be no warranty on the board in that case. You really need to call a repair company who will test everything first.
Dec 27, 2015 | Fisher and Paykel Washing Machines
I blew fuse in my Technic SU D7000 .iv open this thing and i cudnt find where the fuse. Where the hell is fuse in this model. Help please somebody
One of two places...either at rear next to the power supply lead usually a small black plastic screw in cap.....or on the power supply board itself which is easily identifiable as it is the glass fuse in the event of not finding what looks like a fuse then it may have a soldered in diode.you need to obtain a schematic for that make and model.and understand how to use a meter to check.
Apr 13, 2015 | Audio Players & Recorders
Fisher Paykal error 49
In the AquaSmart machines the pump over currents and blows the water valves fuse 1.6 Amp glass, The motor controller board
would be faulty as well and need repair.
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
Jan 05, 2014 | Fisher and Paykel Aquasmart wl80t65c
Fisher & Paykel Aquasmart WL80T65C 5 years old with fault 245, then 49.
Error code 245 is pump stall.
If the 1.6amp glass fuse has blown, the five mosfets on right side have shorted out there legs & blown the fuse.
Also check the pump drive parts for shorted legs.
There are three resistor that burn out near the fuse.
I will up loaded some pictures later.
Feb 08, 2013 | Fisher and Paykel Aquasmart wl80t65c
Blown main ac fuse
a FEW ways this happens.
If fuse blows instantly when set plugged into power either a generic fuse (lots of these fuses are special and a generic will pop for no reason) or a dead short on the primary side of the power supply.
If fuse blows instantly when turned on a short either in secondary side of power supply or something it feeds.
First to try is get the exact fuse used (buy a pair) and see what happens.
beyond that if secondary side (when set is turned on) have an expert look at the set.
Apr 29, 2012 | Televison & Video
Jbl eon15p-1 my speaker it was working fine after 30 minuts wont turn on
Mine has a blown power supply transformer. There are 2 fuses on the power input board. One of the fuses on mine blows instantly because the primary on the tranformer has gone short cct. A $200 part from Jands !!!
Jan 07, 2009 | JBL Eon15P-1 Main / Stereo Speaker
My bass guitar amp is blowing fuses
This sounds like the main rectifier diode/bridge is shorted. If you can rpovide the make and model, I may be able to give you more details.
Thanks,
Dan
Nov 25, 2008 | Audio Players & Recorders
Yamaha P-4500
Hi radek
If it is a toroidal,they have a nasty habit of going shorted turns on the primary. Is it blowing fuses? Let me know
robotek
ex In'gill ;)
Sep 12, 2008 | Yamaha P4500 Power Amplifier 2-Channel
Instantly blows the 5 amp fuse next to the power cord plug.
You have a short in the power supply. Look at the regulator and or rectifier diodes. These are all on th primary side of the SMPS (switched mode power supply) the secondary side if shorted shouldn't cause a blown fuse at all.
Mar 18, 2007 | Mitsubishi VS-50607 50" Rear Projection...
 Grubhead
Grubhead
