Question about Sony Cyber-shot DSC-S700 Digital Camera
S700 Digimax 0
When I turn the camera on the green power light goes out with in a second or two, the camera then sounds out with three beeps.The screen does not power up. Can some one help out a newby to this digital camera?
  • p-61nghtflr May 13, 2008
    Thankyou for trying .Got word fronm the person I got the camera from and it seems the camera was dropped at some point.It may have to be sent to a service center.Again thankyou, jayzone2k1.
  • 57 Answers
First check to see if it's a power issue. Try different types of batteries one that will turn it on. The problem could be that the battery type setting on the camera is different then the type you are trying to use.
Posted on May 10, 2008
My samsung s700 camera wont turn on its beep three times but wont turn on
try charging the battery or using a new battery. if that doesnt work you should probably send it in to be looked at.
May 04, 2011 | Samsung Digimax S700 Digital Camera
Samsung digimax s700 gives 3 beeps and turns off
The Samsung digimax takes standard AA batteries (but you already new that). The beeps sound like a flat battery warning.
A lot of reviews of this camera note its very high drain on batteries. Are you using good quality AA batteries (for example Duracell M3 or Energizer lithiums)?
If you are trying to run it with "very inexpensive" alkalines (or worse yet - common zincs), then you may proceed directly to flat battery warning, as they cannot provide enough sustained current to run it.
Feb 28, 2010 | Samsung Digimax S700 Digital Camera
My samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
It dont turn on
dont buy this c*#p again thats the best solution i can give
Jun 23, 2008 | Samsung Digimax S700 Digital Camera
Digimax l60
I don't know, it's not powering up......
Jan 03, 2008 | Samsung Digimax L60 Digital Camera
SAMSUNG DIGIMAX A 7
Sounds like a power issue. Make sure you use the recommended batteries. Also, some cameras have settings to where you need to change it in accordance to the type of batteries you are using. exp. alkaline, ni'mh, etc.
Dec 31, 2007 | Samsung Digimax S700 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Oct 28, 2007 | Samsung Digimax S800 Digital Camera
Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
Oct 10, 2007 | Samsung Digimax S700 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
47 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
