Question about SanDisk Sansa Clip MP3 Player
While i am listening to songs suddenly it stopped working i tried to reset but still not working . my sandisk-sansa mp3 is not getting charged even though its connected
  • 70 Answers
Sounds like its defective if it is not charging. Or the battery is going bad, is there a way you can replace the battery? As for it suddenly stopping, try a different album, maybe its specific mp3s that are corrupt? All else fails call up the company and see what they say.
Posted on Sep 02, 2010
I Was Just Listening To My Mp3 Player, Then The Song Stopped, And Froze, So I Turned the Switch Off, And Now It Wont Turn On. I Tried The Reset Button But That Didn't Work Either. My Mp3 Is One Of Those...
Leave it on charge for at least four hours.
See if it works.
If it has charged from that port on your computer before the port should be ok.
You could try a different port if you have one.
If no luck, try a different charging cable or charger if you have one.
Charging is discussed on page 7 of the manual.
www.sandisk.com/Assets/File/pdf/retail/Sansa_e200_UserManual.pdf
If it is only a month old, it may be under warranty.
Ask where you got it from, or contact Sandisk.
The page for the Sansa is here www.sandisk.com/products/sansa-music-and-video-players
Feb 01, 2011 | SanDisk Sansa e250 MP3 Player
My sansa e250R stopped working
try holding down the power button for 20 seconds
Feb 08, 2009 | SanDisk Sansa e250 MP3 Player
I try to listen to one particular song, but Sansaclip 2gb freezes
Epsilon - delete that one song and see if the other songs play fine
unschool:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
MP3 not playing the songs and gets restarted
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Oct 15, 2008 | SanDisk Sansa e270 MP3 Player
I have a sansa sandisk mp3 player. when i bought it it was working excellent.but all of a sudden it stopped working.this mp3 has no reset button i do not know how to fix the problem. sansa sandisk...
1. Are you able to turn it on ?
If so, press the the "power on" button the second time to activate the menu.
Still no luck ! Try putting in a new battery and try again.
2. You cannot "reset" anything.
3. Open up "windows explorer"
4. Scroll down the left pane of the window till you see the "sansa" removable disk
5. Right click it and select "format"
6. After formatting, try adding your files back again.
7. Use the >= button on the player tp play the songs.
Hope this has been helpful to you.
Aug 29, 2008 | SanDisk Sansa m240 MP3 Player
Sansa 280e mp3 player
Call technical suport at Sandisk. You might have a corrupt file. They will walk you through the steps. You may have to reformat which means you will lose everything you already loaded. I've had mine for about a year and it's still working fine. You may need to load the latest firmware as well.
May 31, 2008 | SanDisk Sansa E280 MP3 Player
My M240 sandisk is frozen
Attention: Resetting the device will delete all the songs
Thank you
Computerrep
May 30, 2008 | SanDisk Sansa m240 MP3 Player
Sansa e260 sync problem
Reformat and get the latest firmware upgrade from Sandisk
May 29, 2008 | SanDisk Sansa e260 MP3 Player
Sansa shutting off during song
this is normal for this player - it goes to sleep fairly quickly - se p.35 of manual to see how to change frequency of shut off
Apr 18, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
105 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
