Question about Bose Cinemate Digital Home Theater System Speaker
Interface module will not power on
Why is it not recieving signal?
I have unplugged,and checked all connections,and have new batteries in remote.
I did the same and it worked once...spoke to "Phil" at Bose today--5/11/08 and after explaining that this was the second time and second interface mod that is having the same prob...he suggested that it is the bass module. So he emailed me a UPS shipping label to cover the cost of shipping back to MA. I am shipping the bass mod and interface mod. He said they will repair at no cost and re issue another 1 year warranty. info only: I have only had this system since Oct of 2007 and I have had the problem twice. The first solution was for bose to send me an interface mod free of charge due to the fact that the system is still under warranty.
If yous is still under warranty, I suggest you call them...if not, either buy another interface or new brand....I think this is an ongoing problem with the cinemate and THEY have NO solution either.
Posted on May 12, 2008
Lifestyle 50 not responding
Reconnect the Bose link connection at the Multi room interface and at the Acoustimass Module.If this doesn't help,change the remote control batteries.If the it still display "no response",it means either the interface or remote is bad
Jul 28, 2013 | Bose Lifestyle 40/50 Music Center Used...
Hi I have a Aldi bauhn LCD tv and its not recieving the remote signal. I have checked through a camera for the remote control light signal and it works with every button. So that leaves the reciever
Will cost more to fix then a new unit , replace it and try to buy a extended warranty with the new one, most times you can get 3 years after the original warranty runs out.
Apr 04, 2017 | Televison & Video
Westinghouse tv turns off with rmote but cannot be turned on unless button on tv itself is used
How old are the batteries in the remotes? The on/off signal from the remote is the same. There is some lattitude in the IR reciever module for what it accepts. Low battereis may be shifting the signal's frequency or light intensity enough for it to not be recognized.
If sunlight is failing on the sensor or the remote's IR emitter, that can cause interference. Other IR devices can also interfere with the IR signal such as a "Remote Extender" being used for something else.
It may sound odd, but if your remote was working one day and not the next- was the room rearranged? If so, look around for possible sources of interference blocking the beam from the remote, or shining or reflecting light onto the IR reciever module in the set.
Dec 30, 2011 | Westinghouse Televison & Video
My power door locks do not work, when i use my remote transmitter. what problems might there be.
Key fob may need new battery.
Door lock module not recieving signal from key fob.
Key fob needs to be recognized by the receiver module, you will have to set it up to do so or a locksmith can do this for you.
Check those first then go from there.
Apr 01, 2010 | 2003 Honda Civic
Same problem. Bose CineMate light went red and doesn't come back green even if I tried changing batteries and doing 5 step approach mentioned above.
If resetting this system and re-seating the interface (box with light) to the bass module doesn't fix this, you may need a new interface module. This sells for about $40-50 from Bose. If this is under it's 1-yr warranty, they should be able to replace this for free.
So just incase you haven't tried it: 1. Unplug the power cord from the bass module (sub-woofer) along with the interface module and wait at least 30+ seconds. 2. Re-connect the interface first- screw it in as tight as can be. 3. Re-connect the power cord, and try the remote again.
This is really the only solution, and it's exactly what their tech support will have you try. That's the one functionally weak point with that system, that little module needs to be adjusted and re-seated from time to time.
Jun 15, 2009 | Bose Cinemate Digital Home Theater System...
Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
Jun 08, 2009 | Bose Cinemate Digital Home Theater System...
Got a new remote for my viper 791XZ and reprogrammed it .
this usually means that the remote did not recieve a signal back from the module or the module did not recieve the remote signal
have you tried repeatively to press the unlock button? does the remote starter work or aux( trunk ) ?
also when putting the battery in the remote , be easy because there is a connector plug soldered on the board real close to where the battery is , and if it is hit by the battery hard enough it will cause those solder connections to disconnect and you will get the beeps and or other malfunctions
Jan 31, 2009 | 791XV The 791XV is a 2-way Security and...
Reciever
"no signal" means the unit thinks it is not getting signal from the dish. try reset by holding down the power button on the unit for up to 10 seconds. it will acquire sat and then load guide. this makes the unit "think" again. also check to be sure the cable fitting "stinger" is straight. no signal could also mean the tv or vcr is off channel or is not connected or inputted properly with the original tv remote.
Feb 15, 2008 | RCA DISH Network(r) 311 Satellite System
Bose Cinemate Home Theater
Hello everyone! The Bose interface module is working again. All I did was unplug the power, wait about a minute and then plugged it back in. Whatever it did, it must have reset itself, so now everything is fine.
Nov 18, 2007 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Digital Home Theater System Speaker Logo
697 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
