Question about Magellan GPS 310 GPS Receiver
Have a magellan 310 that turns it self of at random like it s got flat batteries. Then fails to switch on for a while. It also wouldn't track but for some reason it does now. Can this be fixed. I have never reset it. would this help. Thanks Steve.
  • 3,083 Answers
This could be a software problem, and resetting it might help, but it sounds like a hardware problem, maybe oxidation on some contacts, or possible a cracked solder joint in the power switch, or something like that. I read some reviews on this device, and saw mostly negative reviews and dissatisfied customers, more the most part. Here's the site:
http://wize.com/gps-devices/p422584-magellan-gps-310-handheld-receiver
I would normally recommend contacting Magellan Support, but after reading all the bad experiences people have had, I can't really recommend that, in this case, but you might be the lucky one.
http://support.magellangps.com/support/index.php?group=default&languageid=1
You might take it apart and spray switches with electrical contact cleaner, and look for cracked solder joints, etc., but the problem could require servicing.
Good luck, hope this helps, and wish there was better news.
Posted on Sep 02, 2010
Magellan 315 lines across scree
if those lines are vertical it simply means that your batteries are weak. you could try cleaning the contacts careful - battery ends as well
May 14, 2012 | Magellan 12, 310, 315, 320
Self tests show ok, reset ok, satellite just says searching
make sure the battery is charged up good, then take it outside and turn it on and leave it in clear view of the open sky for up to 30 minutes to acquire the satellites especially if its been reset.
if that fails, reset the unit...turn it on, then slide the reset switch on the top of your 800 to the opposite position and once it turns off, slide the reset back to the normal position and turn it on again and take it back outside and let it in clear view of the open sky for up to 30 minutes.
if that fails..go HERE and get the update for which ever 800 model you have...you will have to sign on to the Magellan site before you can download anything.
if you need more help, just post back
bill
Jul 04, 2010 | Magellan RoadMate 800 GPS Receiver
When I turn it on, it is looking for satelites constantly and never locks on to one. I have done the reset numerous times. I have not used this for over a year. The batteries were removed and it was stored...
Since the batteries were removed, the unit loses its memory in 20 minutes so that the GPS now has no idea where it is on the planet or even the time and date.
SO, it likely needs to be initialized.
Here is the owner's manual, initialize procedure is on page 4.
Hopefully this'll get you back on track.
Good Luck!
Apr 30, 2010 | Magellan GPS 310 GPS Receiver
Not tracking
Reset the unit by clearing the memory. Hold the RIGHT ARROW key and press the POWER BUTTON, while holdingthe RIGHT ARROW key until the DELETE MEMORY screen appears. Select YES and press ENTER. Then procede to initialize the GPS. Leave it outdoors for an hour or so to acquire satelite feed.
Apr 20, 2009 | Magellan GPS 310 GPS Receiver
Magellan GPS 310 screen or software gone haywire...
the motherboard is probley sendint the screen on the gps the wrong info
your best bet would be to take it into a gps place and get them to have a look at it
Jul 19, 2008 | Magellan GPS 310 GPS Receiver
Car Power Unit
I'm not sure that there is a car charger available for the GPS 310. There is no external port where you could plug it in, the only thing you can do for power is take extra AA batteries with you.
Jul 02, 2008 | Magellan GPS 310 GPS Receiver
Magellan 310
I Experienced the same problem the last two weeks. I read your suggestion about the right key/power button. The GPS asked me wheter I wanted to clear the memory yes or no. After "yes" i had to reenter my country and date/time. After doing this it took gps310 more than an hour to get its first fix. But it works again.
May 21, 2008 | Magellan GPS 310 GPS Receiver
MAGELLAN 310 NOT TRACKING
Turn on the power while holding the right arrow. This resets the unit. You will then have to reset the time, date, and location.
Jan 22, 2008 | Magellan GPS 310 GPS Receiver
I can't find my owner's manual
You can download a pdf of the owner's manual here: http://www.magellangps.com/assets/manuals/gps_310_315_en.pdf
Aug 12, 2007 | Magellan GPS 310 GPS Receiver
Magellan GPS 310 GPS Receiver Logo
52 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
