Question about Dryers
Loud dryer dryer sounds like a large rock tumbler.
  • Dave117
    Dave117 May 11, 2010
    Probably bearing failure.. usually caused by overheating.. Has the lint filter been cleaned on a regular basis? If it is the bearings, it's quite a major job to fix. You might be able to prove this by attempting to move the inner drum by hand.. Eg see if there is any play or movement up & down in the actual drum or inner lining, where you put the clothes. Anyway, unless there is something metalic or hard trapped in the drum somewhere, it's most likely to be bearings.Rgds,
  • 3,587 Answers
Sounds like somethings stuck inside the drum, between outer wall of drum and cabinet...please inspect for loose items..
Posted on May 10, 2008
Dryer making loud vibrating noise
In all likelihood, the belt that runs the tumbler is loose, causing the tumbler to rotate off center. While it takes a few minutes, the front of the dryer should be removable and you can take the tumbler out and replace the belt.
Oct 11, 2014 | Amana Dryers
My older Maytag dryer is making the classic rumbling noise when running. Heat seems fine. I can turn the tumbler by hand and sound like one of the tumbler wheels is vibraiting or wobbeling. what else...
Replace all drum wheels. I would replace the idler pulley and belt if the belt looks worn. Check front and rear felts for excessive wear. Check the blower wheel. Here is a link that should help
Aug 09, 2010 | Maytag Dryers
Loud noise as the tumbler is drying
Front or rear? Rear is probably center bearing. Fornt is front tub wheel or glide worn out. If noise is in front remove front and inspect.
Jul 19, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Loud squeaking noise
it sounds like your roller bearings are bad you need to get the top open then take the front off loosen the belt take out the tumbler try to squirt oil on the shaft the rollers are on there should be two of them,put it back together and try it,if that doesn't work replace them.
Dec 21, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer makes loud sound while running sounds like a bearing
a lot fo things cause noisey dryer . ( look for wire clothing stays in drum/ pins in the felts back and front. or dad may have left a sheet rock screw in his pocket . or a key / these things we take out of dryers every day . look hard . i think you will find some thing .. slow sounding noises are related to the drum . fast and hi pitched noise repate to motor and drive componet's .. mm
Dec 12, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool Duet Sport Gas Dryer - Works fine but makes loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Nov 24, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Loud Noise when drying....
hi thanks for the question tome iot sounds like the blower a rumbling noise and the dryer takes too long to dry so i would check that thanks the appliance doc
Sep 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Dryers Logo
81 people viewed this question
Top Dryers Experts
