My smartboard is projecting the correct image except it has a blue tint. have tried changing display settings back to default but have same issue again
  • 1153 Answers
SOURCE: color problem with DLP TV
If pic. is distorted when warm :. Suspect the FMT PCB part # 930B924002
Posted on Aug 22, 2007
DJYar
  • 41 Answers
SOURCE: tinted image
If you are plugging in a monitor cable, it is most likely a cable issue. I would try another cable and make sure the cable is seated firmly into the projector. If that doesn't help, check the port on the projector for bent or missing pins because it seems that not all of the video information is reaching the unit.
Posted on Aug 23, 2007
humanman42
  • 82 Answers
SOURCE: blue tint on computer display monitor
Try
1. Unplugging the video cord from the back of the computer (and screen if it comes off) and plugging it back in. Sometimes it can become loose and cause a screen to have a abnormal color contrast
2. Updating the drivers to your card
3. Trying a different monitor on the computer. Mind you, if you plug in a differant monitor and the color stays the same. Check the videocards pins on the back of the card. I dont know if you gave all the info on how it became like this, so maybe it got undone and plugged back in forcably and one of them got bent? I
Also if the pigment goes away. Plug the normal one back in and if its gone, great!, if its back. Try the OSD settings on that monitor. Still no luck. The monitor is junk.
Hope that helps
Posted on Dec 01, 2008
Nic61
  • 1073 Answers
SOURCE: Yellowed image projection
The yellow you see is all dust on the mirrrors inside your projector.
If u are lucky you can get the mirrors cleaned by a pro, if you are unlycky as i was, the blue mirror has burn and u need to replace it.
Take your projector to someone who repaire tv:s ot other electronics, they will help you. If its only the cleaning its cheap, if you need to replace a mirror its expensive.
Good luck
Posted on Dec 02, 2008
SOURCE: yellow-green tint
I had the same problem and found out that it was the cable from the projector to the computer. HD D-sub 15-pin cable.
Posted on Apr 08, 2011
My sony KP-46WT510 has double images and the edges are red and green
Try pressing the Flash Focus button on the TV to adjust the convergence of the TV.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 22, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a 42 Sony flat screen it has a blue blob in the lower left corner what do I do to correct this?
Jul 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Jul 18, 2009 | Samsung HLN5065W 50" Rear Projection...
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
My screen has gotten much darker
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 24, 2008 | Hitachi 53SWX12B 53" Rear Projection...
Projected image is not the same as computer monitor
as long as nobody has physically changed the lens poition, you can go into the menu on the projector and do a factory reset. this should default the settings back to where the installer put them.
Feb 05, 2008 | Mitsubishi ES100U Multimedia Projector
Overall Blue Tint
You might try resetting the "settings" to factory defaults and then scanning again. I have seen strange tints if the settings get set incorrectly, not sure exactly what is wrong. However, using factory defaults corrects the problem, then change settings one at a time.
Jan 12, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
Video Problems with Windows Media Player
Why is the projected video black in the Player? If you can see the Player, but the Video and Visualization pane is black, this usually indicates that your video card is not configured correctly. You can usually correct this problem by changing the video acceleration and/or overlay settings for your video card. To change video acceleration, do the following: 1. In Windows Media Player, on the Tools menu, click Options. 2. In the Options dialog box, click the Performance tab. 3. In the Video Acceleration area, move the slider to adjust the video-acceleration capabilities of your video hardware. Drag the slider to Full to use all available video acceleration. Drag the slider to None to use basic video-acceleration settings that work with most video hardware. To change overlay settings, do the following: 1. In Windows Media Player, on the Tools menu, click Options. 2. In the Options dialog box, click the Performance tab. 3. In the Video Acceleration area, click the Advanced button. 4. In the Video Acceleration Settings dialog box, under Video Acceleration, clear the Use overlays check box.
Aug 18, 2007 | Smart Technologies SMART Board 580 (SB580)
Color problem with DLP TV
Sep 24, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Computers & Internet Logo
309 people viewed this question
David Payne
David Payne
