Question about Maytag EPIC MFW9700S Front Load Washer
When I open the door of my wash machine it smells bad. What would cause this? Is there a lent trap with lent in it, causing this? If so were is the lent trap? Matag Neptune Washer.
    Scholar:
  • 91 Answers
Hi dear.I'm bit foreign to this model of Maytag.There for I do not know exactly where is the lint filter on it (Refer it's user manual)but I can help with the Bad Odour.If you are doing COLD WASH most of the time with your washer bad odour happens because of body oil & some other deposits(residue) left or sticks the drum after each wash.Cold wash cause that & if it gets worst mould problem going to start up.That's why you have to run the machine empty on Hottest Cotton wash cycle with some bleach every 6-8 weeks to get rid off residue.You'll see the difference.I hope that helps.Thanks.
Posted on Sep 02, 2010
Horrible damp smell in my easi logic 1500 washing machine, what's the best cause of action?
Check the drainage of the machine.nothing like stagnant water sitting in the hoses and bottom of machine to cause smells.first check the penny / button trap for coins or debris as this will cause unsatisfactory emptying .do a rinse cycle with no cloths in machine.Get some calgon or anything that removes washing machine or dishwasher lime scale.then do a full wash without clothes on 60 degrees or above with small amount of bleach and lime scale remover.make sure the room is well ventilated.never overfill machine with dirty laundry when washing as this prevents the rinse cycles from removing bad water completely.try leaving the door slightly open between washes but only if you have no pets or children to prevent build up of damp spores.
Feb 19, 2015 | Washing Machines
Smoke, burning smell coming from my machine. Door wont open and clothes and water inside is black
the bad smell you refer to is a smell of the electric motor burned out have the motor replaced the machine should be ok
Nov 23, 2017 | Whirlpool Washing Machines
Where is the lent trap on the estate washer
If it is like my Kenmore washer, you need to remove the front panel at the base of the machine. You should see the trap front and center, caution when you open the trap there will be water coming out. good luck
Sep 06, 2014 | Estate Washing Machines
The controller has a burnt smell
If the washer is still was your cloth to the end cycle that ,ean the machine is good. To prevent the smell, make sure leave the door open after use. so the moisture not trap in the machine which can cause to smell for the next time you use.
Jan 04, 2014 | Kenmore Washing Machines
O.k. If it does not have a lent trap where does the lent go ?
The lint will build up in your ventilation tube very rapidly and become a fire hazard. It will also get all over the wiring inside of your dryer and cause shorts. This will happen anyway but over a length of time. Bottom line...keep your lint trap in, clean it regularly, an stay on top of cleaning your vent line as well.
Sep 21, 2012 | Kenmore 22422 Top Load Washer
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
Cannot locate pump filter to clean. Trying to eliminate the STINK
The filter if you want to call it one consists of a coin cup inserted inside the most rediculas tub to pump boot everthemobilian_3010.jpg
Affinity Service manual
Sep 12, 2011 | Frigidaire ATF6000ES Front Load Washer
Foul odor from front load washing machine
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Nov 06, 2009 | Washing Machines
Slimy mold in rubber seal
Hi, Just dry the seal after a wash and leave the door open just a little. Leaving the door cracked will also help with the smell allowing air to circulate through the machine. ALL front loads have this problem with mold and that strange smell.
Sep 05, 2009 | Washing Machines
Maytag EPIC MFW9700S Front Load Washer Logo
129 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
