Graphics trying to play a game ,game installs correctly but when i click on the icon a black screen apears and notr comes up sayin (creat divies fails )
  • balas 5 Jun 19, 2008
    i unable to play games
  • sashang Mar 12, 2009
    game will not run
U r graphic card is to support that game i have also same proublem but now i dont have
Posted on Mar 12, 2009
  • 32 Answers
This "create device fails" error normally occurs on computers with integrated video cards. To resolve this situation you need to buy a new video card that meets at least the minimum game video requirements and install it in the computer. If this is occuring on a laptop you can't upgrade the video and will need a new laptop with dedicated graphics.
Posted on May 10, 2008
    Sergeant:
  • 221 Answers
Try putting the installation cd back in the drive, then click on the icon.
Black screen card
Make sure that you have the latest display (Graphic) driver installed on the comuter. If you are still facing this problem then it might be that your computer graphic card is old and does not support the required graphic resolution which is required to play this game.
You can try--
Most of the time DPI (Dot per inch) setting also fix this type of issue.
You can change the DPI settings in windows Xp by following these steps:
1. Click on Start then Control Panel.
2. If control panel is set at Classic View, then double-click on the Display icon
3. A box will pop up. Click on the Settings tab.
4. Click on Advanced.
Change the DPI setting to Normal size (96 DPI). You can also change the DPI size to any other value. Click OK and your computer will ask you to reboot your computer. Click Yes
Nov 16, 2013 | NovaLogic Delta Force 2
Black screen
Try updating or clean re-installing your graphic card driver... Also make sure you meet requirements to play the game.
If nothing helps, it could be faulty game, or a problem with your graphic card.
Does it happen with other games and did you ever manage to play this game in the past?
May 23, 2013 | Infogrames Project IGI I'm Going In 2:...
Game not working
i installed the game ... did everything in read me doc ... but it's given an error saying , graphic serviecs faild to initialize .
Jul 23, 2009 | Philips Sonic Edge 5.1 PSC605 Sound Card
The graphic organizer won't work it says i need DirectX 9.0c
First thing you do is check your system requierments,(should be located on the back of your CD case, or somewhere in your manuel, probebly under the title "System Requirments") it will probebly say something like "complete Direct-X compatible graphics adapter requiered". You then go to Start Menu-->Run (type in "dxdiag" (without quotes)) and see if you have the correct graphics card, and or graphics adapter.
If you do have the correct system requierments repost your problem saying you have the correct system requierments but you still get the following message: "Failed to find any Directx9.0 compatible graphics adapters in this system! Please make sure you have a DirectX 9.0c compatible graphics adapter and have installed the latest drivers provide by the manufactuer. The application will now terminate."
If you do not have the correct system requierments, you cannot play the game on that computer.
Hope this helps.
Levi_xx
Jul 10, 2009 | EA - Electronic Arts The Sims Double...
My pc has create a problem that has problem when i start game i
If you would have listed the model & manufacture of your graphics card or if the graphics card is built into the board the (Model number of the motherboard)
Or if the graphics card has been added to your system, (The name of card & model number).
Finding an answer for your problem would go a bit faster & be more accurate.
If your graphics card is built into your motherboard or if the graphics card is installed into an AGP/PCI or PCI-E port, you'll need to uninstall your graphics driver software. The error message you posted; (Your display driver created a problem). One or more driver files are most likely corrupt.
To correct this you will need to open windows control panel. Than open the icon, Add/Remove programs. Find your graphics driver software & uninstall it. After which windows will want to restart.
(Do so). When windows finishes loading re-install the driver software for your graphics card. (Your graphics driver software should be on a CD).
Than restart windows, even if windows does not ask you too. When windows finishes loading again. Load windows update service. Click the start button, slide your mouse to All Programs, than slide to & click on Windows update. Install any updates windows finds.
(Do not install windows explorer version 8.0) Too many bugs in version 8.0.
While on windows update site look to the left. If you see that windows also has hardware updates, include these in the update process. (Restart your system when downloading is finished or if windows request it).
Lastly, before you try playing a game download & run this free program named RegCure. (This program will clean your system from left over junk& non needed files).
Click on the link below to download RegCure;
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
If you still receive en error message or if your game locks up/ freezes, provide the information I mentioned above so I can better help find a fix.
Cheers!
Thanks for using FixYa!
Mike
Jun 02, 2009 | Computers & Internet
Installed still life and it wont play , it says game is running
Find the program in the installation directory. It might be something like C:\Program Files\The Adventure Company\Microids\StillLife
Now right-click on Stilllife.exe, then click Properties. Click the Compatibility tab, then select Windows 98/ME from the drop down menu. Hit OK and try to run the game again. It should start up just fine.
May 29, 2009 | Microids Still Life for Windows
Game installed but won't load to play
I have two computer games which are installed into my PC. When I click on the icon(s) nothing happens - in fact, for one of them I get a black,blanck screen which immediately reverts back to the desktop - WHY?
Mar 13, 2009 | M2K Garfield: It's All About Math Math...
ATI Graphics error
Looks like you've got a virus while playing, though that only would happen if your running an illegal copy of the game.
Otherwise while the game hanged, and you inevitably rebooted, the card drivers were damaged and erased from the hard drive. You might be now in low resolution standard VGA that's activated by windows when the drivers fail.
You should be able to still access internet explorer to browse the internet, from there you'll need to go to www.ati.com to download the most recent drivers for your card and reinstall them.
Oct 15, 2008 | ATI RADEON HD 2400 PRO Graphic Card
Gigabyte GV-R7064T RADEON7000
run cc cleaner remove games all the way then run cc cleaner agian then reboot then install games again to test u have all the latest windows updates ? try windows live care see if any traces of bugs thx nick im open for chat also
Jan 07, 2008 | Gigabyte GV-R7064T RADEON7000 64MB DDR...
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
