Question about Crane Plumbing Toilet To Go Tall Elongated Toilet
We have a one piece crane toilet with push button flush which is 20 years old and is constantly leaking. We would like to replace the flush mechanism but where can we find it?
  • BigGrip Sep 02, 2010
    Have you tried craneplumbing.com?
  • 28 Answers
Lowes and Home Depot also carry some flush valves that may fit the crane toilet.
Posted on Sep 02, 2010
Water leaking into bowl
I have the exact same problem with the pfister toilet.Anybody with ananswer??
Mar 14, 2014 | Pfister VTP-E70W Kamato One-Piece Dual...
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
It's leaking from the flush valve. I cleaned the top of the valve lip and replaced the flapper. This improved the problem but it still leaks alittle. The toilet is only two years old (...
You need to replace the flush valve gasket. It comes in a flush valve kit, it's a rubber gasket that goes between the tank and the bowl. You just pull the tank off and it's on the under side of it. Be careful the black stuff on the gasket doesn't come off your hands. Make sure you get the new one on there even and all the way on. This will fix your problem. Good Luck
Tool Belt Diva
www.toolbelt-diva.com
May 15, 2011 | Crane Plumbing 3755 Toilet-To-Go Metro...
My toilet is a duravit 1930 series model with Euro style push flusher rather than handle. Internal flushing mechanism is not traditional float ball. toilet water constantly leaks from tank into bowl...
A fairly easy ( but messy ) fix - get a replacement tank to bowl gasket and bolt kit, shut off water supply, drain tank, remove bolts ( you might have to cut, depending on your water source and minerals in your water). Remove old gasket and clean surface with 00 grade steel wool. Replace gasket, install new bolts, remount tank.
Good luck!!
Nov 17, 2010 | Duravit Tribeca US-Type Elongated Toilet...
I have a Carlyle water saver toilet. The one that has two push buttons built into the toilet tank lid. It is a solid 1 piece toilet. My problem is every hour the toilet is flushing by itself. Had a...
Hello. Your lid has two buttons so you can do a half flush or a full flush. A water saving feature. Since the toilet is flushing by itself every hour or so, you must have a leaking flush valve. Replace the valve to solve that problem. Joe
Oct 12, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
My Crane toilet is slowly leaking into the bowl. It is not the flapper (which I replaced) and doesn't seem to be from high water pressure. Could it be the seal?
Check your over flow pipe in the tank to see if you need to lower the water level amount in the tank. If thats not it, it could be the seal thats under your flapper between the tank and base. Simple fix just alittle time consuming
Sep 24, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
May 26, 2010 | Home
My one piece elongated bowl toilets are filling for no apparent reason between flushes what can I do to fix the problem
it sounds like your flapper (flush valve) is leaking.
if you here your toilet filling up and no one flushed.
push down on flapper to see if you here the water stop leaking out. if so replace flapper. even if toilet is 1yr or less old. could be a bad flapper. hope this helps. duane :)
Oct 11, 2009 | American Standard 2002.014 - Champion4...
Can't remove old assembly...stuck in there
You have to remove the tank bolts on either side of the flush valve. Once you remove it, there is a tank to bowl seal that will need to be replaced. Remove the old seal and there will be a huge plastic nut that holds the flush valve to the tank. Remember to use new hardware when reassembling the toilet so that it won't leak sooner rather than later!
Apr 03, 2009 | Crane Plumbing Toilet To Go Tall...
Need to replace working parts , push button , one piece toilet
Here is a link to a site with a ton of replacement parts for amstan toilets.
Without model numbers etc. its hard to know exactly what parts you need but you should be able to look at the pictures on the site and order the right parts...
http://www.plumbingsupply.com/amstan.html
HOpe that helps...
Jan 27, 2009 | American Standard - Lavatory Faucet -...
Crane Plumbing Toilet To Go  Tall Elongated Toilet  Logo
196 people viewed this question
Top Crane Plumbing Home Experts
john h
Tom Chichester
Jude24
Are you a Crane Plumbing Home Expert? Answer questions, earn points and help others
