Question about Xerox WorkCentre 220 All-In-One Laser Printer
Lsu eror is displaying in printer display - Xerox WorkCentre 220 All-In-One Laser Printer
  • 360 Answers
Hello, you have to replace laser scanner unit (LSU UNIT)
Posted on Sep 02, 2010
At first it occured a paperjam
lsu indicates laser yScan unit is faulty or
Sensor on the right side is disenaged.
Jul 21, 2015 | Samsung SCX 4200 All-In-One Laser Printer
Samsung Printer SCX-4100 LSU Error
Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge in the machine may be dirty. The mirror motor in the LSU could be bad or needs to be cleaned to spin better. The Laser diode may be faulty.
This is not a user-serviceable issue. You will need to contact Samsung for service. You can do it online via Samsung website or contact the vendor to see who will they appoint to service the printer to, especially if it is still under warranty.
Jan 27, 2011 | Samsung SCX-4100 All-In-One Laser Printer
My xerox PE220 machine give LSU error. not any work in done plz give solution
plz solve my problume in my printer workcenter pe220 lsu eror and not working this time to help me plz
Dec 18, 2010 | Office Equipment & Supplies
There's a colour lazer printer 510 in my office, but when, one day, i come to work, the printer screen displayed, PRINTER LSU ERROR. And what can i do about this? Please guide me. thank for your time and...
First just turn it off for ten minutes and then restart it,
There is a fault in the LSU unit.
1. Use EDC mode to test the HSYNC signal and LSU Motor.
2. Check the Harness connected to the Engine Controller and LSU.
2. Check the Harness connected to the Engine Controller and LSU. --> Refit the harness or replace it if it is damaged.
1. Use EDC mode to test the HSYNC signal and LSU Motor. 2. Check the Harness connected to the Engine Controller and LSU. --> Refit the harness or replace it if it is damaged.. 3. Replace the LSU
If the problem still happens call a repair tech.
Dec 01, 2010 | Office Equipment & Supplies
Display reads E-7 03 error code
E7/03 is a lsu error. The LSU is the “printer head” of the printer. But instead of emitting ink, the LSU emits a laser beam, directing it at the drum of the toner cartridge. If replacing the lsu does not fix it it may be the mcu pwb, but most likely the LSU.
May 11, 2010 | Sharp AR-507 Copier
LSU erorr appear in display screen
LSU refers to the long strip of glass / encoder strip inside the top of the cartridge compartment. It could be dirty or dislodged.
Power off the printer
Open the front cover
Lightly pull out the cartridge and keep it flat
Gently swab the LSU. If part of the LSU is hanging, gently put it back in place and reconnect. Be careful not to touch anything else.
Note: If you are unable to reconnect the LSU, the printer will need service.
Put the cartridge back (again, leave it flat).
Close the front cover.
Power the printer back on.
Hope this helps.
Jul 28, 2009 | Dell 1600n All-In-One Laser Printer
I JUST CAN SEE IN THE DISPLAY ERROR LSU. WHAT I CAN DO IT FOR FIX THE PRINTER
Sir I see the error of my printer kindly make me answer for LSU ERROR
thanks
raju kale
Sep 24, 2008 | Samsung SCX 4200 All-In-One Laser Printer
LSU ERROR shows in display panel
The LSU is the Laser Scanning Unit or "printhead". There is a mirror in there that spins really fast, if the mirror spins too slowly (bad motor, low voltage) it gives an error. Sounds like you would need a replacement LSU. Have the printer serviced.
Jan 02, 2008 | Dell 1600n All-In-One Laser Printer
LSU Error
LSU (Laser Scanning Unit) is a device inside the printer that create images on the drum.
If you see LSU Error on the display, it is indicating that there's a problem with LSU unit.
  • Unplug the power cord and plug it back in.
  • Check if the printer makes any humming noise.
If the problem persists or does not make any noise, LSU needs to be replaced.
If your unit is under warranty, please contact our tech support at 800 - 726 - 7864.
Otherwise, please find nearest Samsung Authorized Service center from the link below.
Dec 06, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Xerox WorkCentre 220 All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
