Question about Kohler KOHGP51487 Authorized Original Replacement Part Tank Gasket For All
I have a Kohler toilet. The triangular black gasket between tank and boel needs to be replaced. While I had the tank off, I noticed the large plastic pipe that comes from the tank is threaded like a screw. Is there supposed to be something it srews to? Should there be a donut sized gasket that goes on there?, or is the flange on the rubber triangle all it needs to seal. (mine seemed to be leaking fron that area rather than from the bolt holes as I first suspected).
  • 349 Answers
Inside the tank it has a gasket from the stand pipe to the bottom of the tank. The stand pipe threads go through the tank and a plastic nut holds it to the tank. Then a gasket goes on the nut and threads to make a seal between the tank and bowl. I have included this picture that has the above look. I hope this will be of some help for you.
Posted on Sep 02, 2010
How to remove large gasket from Kohler toilet that leaks
You will need to remove the tank by locating the long screws on each side of the water outflow outlet. Take those bolts out and then you can lift the tank up and thus you will access to the large gasket.
Jan 26, 2015 | Kohler Home
Kohler K-34-39 leaks
Hi James
You need to replace the rubber gasket between the tank and the bow, that is where yoiur tank is leaking from..
Be sure to use a level when tightening down on the screws to keep the tank level
Bud
Apr 20, 2013 | KOHLER Memoirs elongated toilet with...
Memoirs leaking from seal between tank & bowl. Just replaced the gasket and still leaking
In 2008 I bought the Memoirs model that Lowe's was selling. I've had multiple tank/bowl gasket leak problems. When I went to get a replacement gasket this weekend, Kohler had changed the style of the tank/bowl gasket assembly in the current Memoirs model that Lowes sells. I wonder if this is because the old gasket assembly is known to be defective and prone to leaking?
When I called Kohler, it took two customer service associated, but I was granted a WHOLE NEW TOILET with the new style of tank/bowl gasket assembly. I just had to have the receipt for the (3 yrs ago) purchase. Kohler e-mailed a letter for a replacement toilet within about 15 minutes and before the end of the day, I had a whole new toilet in my bathroom.
I'm not a contractor. Just an average homeowner, so I can't say for sure that the old style (large, black, plastic rectangle on the bottom of the tank and a rather thin gasket ring) was defective or not. (At first Kohler offered only a replacement tank, but after hearing the number of times both I *and* plumbers have replaced the gasket, they did authorize the replacement of the entire toilet.)
Apr 10, 2011 | Kohler Home
The three-bolt gasket seal between the upper half and the bowl; how do you get the plastic water flow out from the gasket?
I assume you have separated the tank (the upper part) from the bowl. The rubber gasket just pulls off. Under the gasket you will find a large nut holding the plastic flush pipe to the bowl.
Dec 14, 2010 | Kohler K-11466-0 White Cimarron Comfort...
Loose tank-how to fix
There are two large plastic nuts holding the tank to the bowl underneath and behind the bowl. You need to retighten the plastic nuts. You almost have to lay on your back on the floor to look up under the the tank.
Nov 25, 2010 | Kohler Memoirs toilet tank with Stately...
Jacuzzi sent me new rubber gasket for attaching flapper assembly to tank-(held in place with a large white plastic nut) Does the totally flat side of the rubber washer face the tank or away from the tank?...
The rubber washer goes to the inside of the tank under the flush valve which gets screwed on with the large plastic nut on the bottom side of the tank. Then the foam gasket fits over the plastic nut which goes into the toilet bowl hole for the water to flow into the bowl. Tank needs to be removed from the toilet bowl.
Aug 31, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
I cant get the new flush valve on my kohler 3386 toilet to fit in the hole with the gasket. The foam gasket is quite thick. Is there a trick to doing this short of mutilating the thing?
The foam gasket stays on the inside of the tank, the only part that gets pushed through the hole is the hard plastic threaded part, then you add the rubber washer and the nut from underneath.
Jun 26, 2010 | Kohler - Toilet - One-piece - Gabrielle -...
LOOKING FOR GASKETS & BOLTS BETWEEN TOILET & FLUSH BOX
go to any howm center, plumbing section. The replacement gasket is not the same as the original, however, they do fit. The other choice is go to Kohler resaller.
May 20, 2009 | Kohler Home
Kohler KOHGP51487  Authorized Original Replacement Part Tank Gasket For All Logo
1,402 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
