I need the schematic for a Westinghouse LCM-22W3. Particularly the Power Supply schematic. I took the monitor apart and need to find the value of the caps I took out and where they go. I have new caps for it and want to put them in and get it going.
  • Steve Yelmene
    Steve Yelmene Sep 02, 2010
    Very Helpful, Thanks. More than what I was expecting.
    President:
  • 1,961 Answers
I did not find the right schematic for your power supply board. The power supply board in your lcd used DAC-19M005. For some unit it uses DAC-19M005, its just the same board, only the DAC-19M005 has audio. The image of the board is shown below.
Please take note of the capacitors in the board as it is marked by numbers.
Values for this capacitor will be listed below, so it would be easy for you to replace it with exact value.
220uf 25v - number 1, 3 and 7
1000uf 25v - number 2 and 5
1000uf 10v - number 6
2200uf 10v - number 4
330uf 25v - number 8
I hope you understand it as clearly as stated, otherwise just post back so I could help you further.
Thank you for using Fixya.
Alp
Posted on Sep 02, 2010
How do I convert a Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor into an HDTV?
Dear Amy,
Normally, monitors do not have tuning electronics for capturing TV signals.
Therefore, consider the monitor as a "dumb" unit that only displays information coming from your computer. Also, this unit does not have a HDMI input, but only VGA.
So, you are fated to have this monitor connected to your computer, always.
Now, you may find good software that will "tune" the TV signals from streaming at the Internet and show whatever is being broadcast. The same way you can access YouTube and watch videos these TV tuners will get the streaming signals the TV stations send via Internet (not all do that) and watch the channel in your PC/monitor
Since I do not have additional information about the computer you use I cannot give you other ideas
I hope I have helped you.
May 18, 2014 | Westinghouse 22" LCM-22w3 DVI/VGA LCD...
Can a westinghouse lcm-22w3 be used as a tv
Yes, you will just need to have the right output on your cable box with some conversion. (eg. if you have RGB out of the back of the box you will have to get a break out cable that goes from that to VGA for the back of your monitor.
Apr 28, 2014 | Westinghouse Electric LCM-22W3 22 inch LCD...
My westinghouse LCD LCM22w3 is not turning on. The switch light will turn on for a few seconds but then turns off. I have no imput signal
Helo,
This is a very common problem with the LCM-22W3 monitors. The problem is caused by a failure of the filter capacitors in the power supply board. Here is a link to a repair guide that shows how to open the unit and what to look for and replace to repair the monitor. This is a very easy repair.
http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-22w3/
Jan 26, 2013 | Westinghouse Computers & Internet
Not turning on
Check the capacitors on the power supply board in the unit. This is a very common problem with this unit but it is easy to repair. Here is a link to a repair guide that shows how to open the monitor and what to look for.
I hope this helps.
May 20, 2012 | Westinghouse Electric LCM-22W3 22 inch LCD...
Has power but won't turn on
Make sure that it does the same with other PC first.
You may have problem in the power supply section, look for bad caps first, the problem can also be bad lamps (I had to fix one today with bad lamps assembly). This unit is really hard to disassemble, the switch assembly is attached to the front section, so be REAL careful when the front and the back section come apart, see pictures here: http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LCM-22W3/
Feb 28, 2010 | Westinghouse Electric LCM-22W2 Monitor
Westinghouse LCM 22W3 22" has electric service, but no response
I did not fix the problem, but found out it probably is a power supply which is a very common problem with this design of this make of monitor. I think I need to get to get it fixed by a professional.
thank you Ann Moctezuma
Nov 19, 2009 | Westinghouse Computers & Internet
LCM-22w3 monitor suddenly changed colors. All
Try adjusting the monitor cable that goes from your monitor to the back of your computer.
Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
My monitor will shut itself off randomly
The power supply on this model has a know issue. We just posted the repair guide on our web site at: www.ccl-la.com It gives a step by step repair guide for the Westinghouse LCM-22W3 monitor. If you don't want to do the repair yourself do do offer a repair service for $35 plus return shipping. If youhave any questions just let us know through our web site.
I hope this helps,If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 06, 2009 | Westinghouse LCM-22w2 Television
Dismantling of a Westinghouse LCM-22w3
Make sure that all three screws are removed from the back of the display. This is in addition to the four that hold the stand on.
Feb 12, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Televison & Video Logo
821 people viewed this question
Top Televison & Video Experts
