Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Laars lite 2 Spark egnighter will not spark
I have a costamer who has a laars light 2 and the spark egnighter will not spark. i have it narrowed down to the egnighter or egnighter box(egnighter board).
    Scholar:
    New Friend:
  • 70 Answers
Turn power off first. I would disconnect igniter wire which will be a thick orange wire that comes off of ignition module if it is spark. once you have that the end will look like a spark plug wire take shield away from metal then hold orange wire in hand close but not touching metal turn power on and it will take a couple of minutes before it should start sparking. If you don't see a spark then it is most likely the ignition module. There should be a red light on ignition module that will blink to tell you what the failure is if is is a newer on. When you turn power on to laars light 2 the inducer motor should come on then a pressure switch should send 24volt to gas valve for pilot to lite.Can you smell gas at all when laars should be igniting. If you have any questions fell free to email me back
Posted on May 14, 2008
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
May 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
How do I change a thermal coupler on a laars lite 2 pool heater?
ther is no thermos coupler in lite 2 it has a ignitor depending in what vintage 2 white wies go down either to a box in bottom middle or to lower-right burner check fuses in black cases first if ok change ignitor if bad change fuses
Aug 24, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Electronic spark not working
Lite with a flame the ignition buttons NEVER work even when NEW
http://www.laarsman.co.uk
Miles
May 19, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool heater will not stay lit
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
Miles
Apr 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I need a manual for laars lite 2 125000 btu
Go to the Jandy web site, there you can look up your model and down load a pfd manual free
Jun 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Pilot will not light
If you have not found the problem yeat, it IS the thermocoupling( or pilot generator(same thing))
You may test by placing a multimeter on the red and white leads coming to the gas valve. you do not need to disconnect the leads first but you can
Jun 22, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite 2 - Turns off after 5mins of being on!
This happened to me and the tech came out and change the pressure switch and it worked fine afterwards
Jun 15, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
278 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
