What cable should o use in toshiba 14LS20 LCD/TV to become an computer monitor
  • 108 Answers
SOURCE: LCD tv.
Go to pricewatch.com.....check the appropriate sections. They have pictures. Also, if your computer came with a manual (and if it is equipped properly) it will give you a name...i.e. DVI out. That name equates to a cable you need.....but if your motherboard does not have that "out", then you will have to buy a card. All of that you can not only figure out at pricewatch or the compaq help site but also save a few bucks probably. Hope this helps..Tango.
Posted on Feb 07, 2008
migregorio
  • 42 Answers
SOURCE: How do I connect my Laptop computer to my LCD TV?
Every laptop has at least a VGA (computer video connection) and s-video cable port. A VGA cable is preferred if you want to be able to read text on your LCD TV. Check to make sure that your LCD TV has a VGA connector. It's a port that accepts a 15-pin connection so it's pretty easy to spot if it's there. It's just like a computer monitor cable if that helps. Should be able to find it at any local retail store that carries computers. VGA or RGB cable.
Posted on Apr 12, 2008
SOURCE: LCD Computer monitor as a TV monitor
Get an out of range message
Posted on May 30, 2008
  • 36 Answers
SOURCE: LCD Tv doesnot recieve signal from apple computer
try and borrow an adapter from a friend and see if it works. :)
Posted on Jan 22, 2009
nadereleraki
  • 433 Answers
SOURCE: My LCD tv SyncMaster 910MP
dear\.....
you are use bad type data cable bay original data cable will adjust your color
best regardes
if that helpful plz don't forget vote me
Posted on Mar 29, 2011
Samsung Monitor Model : LS198300NS giving distortion on screen, when I change it with Sony Laptop cable, it becomes ok, but not with a Samsung Cable. What should I do ?
hi
if you monitor is old , it may be due to bad filter caps in the power supply section!
if its not that old then the cable is itself at fault!
Apr 07, 2015 | Coby 20" Flat Screen TFT LCD TV Monitor
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
Connect TOSHIBA SATELLITE A205-S5855 Laptop to TOSHIBA 40H80 TV
You can use the VGA cable which has 15 pins at both ends. For sound, you will need mini stereo phone plug at both ends.
You will have to use the combo key Fn and either F5, 6, or 7 to select the internal, external, both.
Make sure to set the video resolution to the native resolution of this TV otherwise you will get 'Format nor supported' on the screen.
http://s807.photobucket.com/home/budm/allalbums
Jul 02, 2010 | Gateway FPD2275W LCD Monitor
My laptop toshiba S1 is not showing anything on the LCD. it will only show that power is on
This could be coz of three possible reasons, the connector cable problem, RAM got damaged or the LCD is damaged. Try removing ram and start the computer again, if u will see something on the screen, u should replace the RAM, if this does'nt work, u have to take the computer to the service center to check the connector cable or LCD, hope this is helpful
Sep 20, 2009 | Toshiba Tecra S1 Laptop Notebook
Toshiba Satellite L25-S1194 attached to TV monitor can't get display on laptop at same time HELP!!
Connect your TV to the computer with an S-Video cable. Turn the TV on and choose the AV option (of your TV) to S-Video. It will tell you that there is no signal on the TV.Press the Fn key on the keyboard. While keeping that key pressed, press the F5 key. A small rectangle appears on the screen showing different connection possibilities (LCD, LCD +TV, LCD+CRT, TV only, CRT only). You can cycle through the options by pressing F5 repeatedly. You select the output option (TV + LCD).Release the keys . You will then have your two screens.
Note: I assumed you connect the TV through the S-Video. If your TV can be used as a monitor (it has a VGA adaptor), then with the F5 key select option LCD and CRT
Hope it helps
Aug 28, 2009 | Toshiba Computers & Internet
Concerting TV to PC
to my understanding,LCD can only be connected as monitor ,not to become a computer itself.if ever it can be use as one, you'll need all the basic of the computer accessories.wireless modem can be use as long as there is a slot for or the unit is compatible for a wireless connection.check first if there is a socket for keyboards and everything before buying.since it can be connected only by vga cable, i assume that it is for monitor use only,unless you want to use two monitors at the same time.
May 14, 2009 | Televison & Video
No picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Feb 17, 2009 | Toshiba Computers & Internet
It could be used as a monitor if you have on of thoose advanced Digital Tuners, They usually have a DVI or VGA port.Especially the HDTV ones. Connect thoose and you're off. If your monitor supports TV tuning, just connectt eh cable straight away and you should be able to watch TV. I would use digital tuners since they are becoming Widely avaible.
May 28, 2008 | Westinghouse Computers & Internet
Apr 12, 2008 | Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
